Thread: Coolant pump B open cct P261A 00(237)
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: Coolant pump B open cct P261A 00(237)
    #11
    1840 Post(s)
    When I checked they were the same number but you have taken your reg away, Private Message me it.
  2. Re: Coolant pump B open cct P261A 00(237)
    #12
    Jan 2019
    My Reg is VE62 CPF..its a bitdi 2.0 bluemotion.. Seems I've not had 15 posts yet so PM's are disabled..unfortunately.
    Think I mentioned that I could feel the new v51 run when connected with ignition off..when I put the old one back on, it didnt. I then assumed the old pump to be knackered. It doesnt mean that a cheaper replacement is serviceable though..
    Whats funny is it went from being a hard fault to becoming intermittent...hate faults like this, I dont have vcds access locally either and the VW van centre is 40 miles away. Local vw wont look at it in bathgate.
    TOPRAN Additional Water Pump for vehicles without towbar for hot climate zones EL (117 255) buy cheap online
    This link is to the v55 heater circuit pump I believe is fitted in front of the battery, above the nearside wheelarch..
    Thanks for taking the time to help invest. Ive not used the second v51 pump I have yet..
    Rgds
    VAG 20v powered Elise S2 500hp, Amarok 2.0 180 tdi 4motion
  3. Re: Coolant pump B open cct P261A 00(237)
    #13
    Jan 2019
    i'll take the v55 off and check for numbers now......
  4. Re: Coolant pump B open cct P261A 00(237)
    #14
    Jan 2019
    7HO 965 561 = v55? would this pump which is two pole throw up the same code? pump runs when connected..when the engine is warm..
  5. Re: Coolant pump B open cct P261A 00(237)
    #15
    Jan 2019
    ok, I am off to buy an oem pump, I think the ebay item is causing the intermittent issues, I'll let you all know..
  6. Re: Coolant pump B open cct P261A 00(237)
    #16
    Jan 2019
    75 miles so far and all seems well....fingers crossed
  7. Re: Coolant pump B open cct P261A 00(237)
    #17
    Jan 2019
    Ok, conclusion is/was; the aftermarket ebay pump v51 was not of the correct/compatible spec with the ECU, throwing code P261A 00 at random intervals. I assume this was when commanded in one direction or the other by the ecu.
    Hope someone finds this useful and thanks to Crasher for his inputs.
  8. Re: Coolant pump B open cct P261A 00(237)
    #18
    1840 Post(s)
    I am not against aftermarket parts, quite the opposite. I use the trade system Tec Doc to find listed companies who offer cross references and certain companies are very trust worthy such as Febi, VDO and Pierburg, some less so. Before I dive in and use cheap stuff on customers cars, I use myself as a guinea pig such as with secondary air injection pumps. I run a 2003 Octavia VRS which I try and keep environmentally as original. My secondary air injection pump packed up (common issue) and a new VAG part was insane money at £590, more than half the old girls value and even aftermarket was only half this but I found a Chinky one at basically less than knock the zero off and it has been perfect, in fact quieter than the original. It is a case of being careful and selective BUT experience is invaluable. When I suspected this new pump was not good I fitted a new Pierburg inlet valve and all is now good.
  1. Replies: 16
    Last Post: 03-07-2022, 08:15 AM
  2. Question P261A – Coolant Pump 2 issue (pump failure), need advice.
    By jkeeeng in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 07-02-2017, 10:28 PM
  3. P261A error code - auxillary coolant pump B - where is this pump?
    By 3rdpassat in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-07-2015, 08:31 PM
  4. Please Help Coolant Pump v50 open circuit
    By Raflus in forum A8 - S8 - V8
    Last Post: 11-03-2015, 08:19 PM
  5. Please Help Coolant Leak From Coolant\Water pump Housing
    By Chappio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2009, 03:30 PM
