Thread: 2.4 BDV cam belt change
  1. 2.4 BDV cam belt change
    Feb 2009
    Hi All,
    Has anyone done a cambelt change using the "audi" method (as per elsawin) of putting the front into the service position - is there enough room (garages etc seem to take the radiator off which I want to avoid)?
    Car is A4 Cab 2.4 (BDV engine).
    Thanks in advance,
    W.
  2. Re: 2.4 BDV cam belt change
    Mar 2016
    Minervois, France
    53 Post(s)
    I've done it on my 1.8 straight four engine, which may be longer than yours, meaning you have more space, with no particular problem.
    You should make sure that the "lock carrier" is held as far forward as possible by using nuts on the threaded studs used to support it.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  3. Re: 2.4 BDV cam belt change
    1837 Post(s)
    We have done hundreds of Audi and VW V6 cam belts and the service position allows plenty of room. Using the correct locking tools and releasing the cam pulleys is quite important on these engines or you can get crank to cam sync errors.
    I use a pair of vice grips on the sleeve to hold the system forwards against the pull of hoses and to stop it sliding back when leaning on it
    This is an AKE block but the idea is the same
    The only time we ever have to take the front end off is when some moron has previously ruined the crank sprocket bolts as there is not enough room in the service position to attack them, we do this without disturbing the ac circuit, like on this Passat
  1. Change thermostat as part of timing belt change?
    By spartacus 68 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-09-2017, 01:26 PM
  2. Replies: 4
    Last Post: 29-04-2014, 04:47 PM
  3. Question Cam Belt change 60k or 75k?
    By kurtas2006 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-04-2011, 08:08 PM
  4. Cam belt change
    By Lemony_06@yahoo in forum Polo - Derby - Lupo - Fox
    Last Post: 06-11-2008, 09:54 AM
  5. timing belt/ cam belt change
    By jonoallen in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-11-2006, 01:24 PM
