Thread: Help required - Audi A3 8p
Results 1 to 10 of 13
  1. Help required - Audi A3 8p
    May 2016
    Bromsgrove
    Hi guys I have recently purchased a new Audi with issues.
    Audi A3 8p sportback 2007
    Previous owner had his home broken into and the keys stolen to all 4 cars, someone came out and replaced the keys on the other 3 cars but when trying to code the new key to this one they somehow bricked the car. The owner had it towed to his local garage they helped him get mobile by immob off, now I have purchased this car and it has issues with warning lights on the dash and windows not working etc, the following lights on the dash
    Abs
    Traction
    Tpms
    Steering
    Safe displayed
    Now I understand that if immob is off the windows won’t operate?
    I want to resolve the issue with this car I have a used instrument cluster the same part number as the old one, but I don’t have the pin to either dash what’s the best way for me to extract them? I have genuine vcds.
    Also vin on engine ecu and instrument cluster is missing it just says ŷŷŷŷŷ
    I have tried carrying out basic setting for the steering it worked until I turn the ignition off and on it looses the settings
    Any help would be appreciated
  2. Re: Help required - Audi A3 8p
    Oct 2014
    East Londonz
    You got a print out of the fault codes from vcds?
    Block out your chassis number.
    Is there any component protection on the list?
  3. Re: Help required - Audi A3 8p
    May 2016
    Bromsgrove
    Quote Originally Posted by H_MAGIC View Post
    Thanks for the fast reply, I will get one in the morning.
    As far as I’m aware most are coding issues, I also tried to code the abs module but it wouldn’t accept coding but I’ve been told it won’t code if the vin isn’t in the instrument cluster
    Adam
  4. Re: Help required - Audi A3 8p
    Oct 2014
    East Londonz
    It’s probably because the car has not been coded properly and you won’t be able to do that with vcds. You will need someone with access to Odis who has online access.
    Where you based?
  5. Re: Help required - Audi A3 8p
    May 2016
    Bromsgrove
    Ahhh right really? Birmingham, UK
  6. Re: Help required - Audi A3 8p
    May 2016
    Bromsgrove
    Thursday,03,January,2019,12:19:55:22113
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
    VCDS Version: 18.9.0.4
    Data version: 20181017 DS296.0
    Ross-Tech: Home
    Dealer/Shop Name: Grove
    Mileage: 204540km-127095mi Repair Order:
    Chassis Type: XX (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76 77
    VIN: XXXXXXXXXXXXXXXXX Mileage: 204540km-127095miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.clb
    Part No SW: 03G 906 021 LG HW: 03G 906 021 AN
    Component: R4 2,0L EDC G000SG 9828
    Revision: --H07--- Serial number: XXXXXXXXXXXXXX
    Coding: 0000072
    Shop #: WSC 06402 785 00200
    VCID: 6FEBED7C7ECB6D3232-803A
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0007304
    Shop #: WSC 00581 210 01865
    VCID: 73E3E10C12E349D2D6-8026
    5 Faults Found:
    01435 - Brake Pressure Sensor 1 (G201)
    005 - No or Incorrect Basic Setting / Adaptation
    00778 - Steering Angle Sensor (G85)
    01423 - Lateral Acceleration Sensor (G200)
    01044 - Control Module Incorrectly Coded
    003 - Mechanical Failure
    008 - Implausible Signal
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AG HW: 8P0 820 043 AG
    Component: KlimavollautomatH19 0420
    Revision: 164005 Serial number: 8P0820043AG
    Shop #: WSC 06314 000 00000
    VCID: 71EFEB0468FF7BC224-8024
    4 Faults Found:
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 147
    Mileage: 204456 km
    Time Indication: 0
    Date: 2017.09.15
    Time: 00:18:05
    Freeze Frame:
    Voltage: 8.00 V
    01334 - Door Control Module; Rear Right (J389)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 152
    Mileage: 204547 km
    Time Indication: 0
    Date: 2019.01.02
    Time: 13:12:37
    Freeze Frame:
    ON
    00796 - Fan for Interior Temp Sensor (V42)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 150
    Mileage: 204456 km
    Time Indication: 0
    Date: 2018.04.09
    Time: 00:52:33
    Freeze Frame:
    Voltage: 10.00 V
    Temperature: 3.0°C
    01331 - Door Control Module; Driver Side (J386)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 152
    Mileage: 204547 km
    Time Indication: 0
    Date: 2019.01.02
    Time: 13:12:37
    Freeze Frame:
    ON
    Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
    Component: Bordnetz-SG H54 2501
    Revision: 00H54000 Serial number: 00000007360158
    Coding: E5881F01B0141000471600001600000000085E175C01000000 0000000000
    Shop #: WSC 06314 000 08192
    VCID: 45876FD40CF78762A8-8010
    Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0090
    Coding: 00150573
    Shop #: WSC 06314
    2 Faults Found:
    02395 - Parking Light Front Right (M3)
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 152
    Mileage: 204547 km
    Time Indication: 0
    Date: 2019.01.03
    Time: 12:14:00
    Freeze Frame:
    ON
    Voltage: 11.60 V
    ON
    ON
    OFF
    OFF
    OFF
    00984 - Left Tail Light (M4)
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 112
    Mileage: 204547 km
    Time Indication: 0
    Date: 2019.01.03
    Time: 12:14:00
    Freeze Frame:
    ON
    Voltage: 13.45 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 L HW: 8P0 959 655 L
    Component: Airbag 9.41 H01 4210
    Revision: 91H01421 Serial number: 003CP0007WHA
    Coding: 0071612
    VCID: 4B9359EC2A9371127E-801E
    Subsystem 1 - Serial number: 6332DRB40585D320J
    Subsystem 2 - Serial number: 6342DRB4058394A6T
    Subsystem 3 - Serial number: 63528RB402A38CC4V
    Subsystem 4 - Serial number: 63628RB402A43C25J
    Subsystem 5 - Serial number: 63747RB40268EABF6
    Subsystem 6 - Serial number: 63847RB40268EAC81
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0004042
    VCID: 418F7BC418DFAB4294-8014
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 981 K HW: 8P0 920 981 K
    Component: KOMBIINSTR. VDO H20 0640
    Revision: D0H20001 Serial number: 2246G001003799
    Coding: 0004428
    Shop #: WSC 01286 386 08256
    VCID: 40897EC013D5A24A9B-8014
    1 Fault Found:
    00003 - Control Module
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 204547 km
    Time Indication: 0
    Date: 2019.01.03
    Time: 11:59:11
    Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 L HW: 1K0 907 951
    Component: J533__Gateway H15 0180
    Revision: H15 Serial number: 1400K0763080F4
    Coding: E9807F0E0006022103
    VCID: 30692E00A37532CA6B-8064
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H20001 Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
    Shop #: WSC 00597 210 10101
    1 Fault Found:
    16346 - Control Module - ROM Error
    014 - Defective
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
    Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
    Component: Tuer-SG H03 0060
    Coding: 0004856
    VCID: 428D74C81DD9B05A8D-8016
    Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
    Part No: 1K2 909 144 M
    Component: EPS_ZFLS Kl.079 H08 1901
    Shop #: WSC 02069 000 90108
    VCID: 3665181841111CFA31-8062
    2 Faults Found:
    02546 - Steering Limit Stop
    Freeze Frame:
    Mileage: 204540 km
    Temperature: 10.0°C
    Voltage: 13.50 V
    Voltage: 13.30 V
    000 - -
    Freeze Frame:
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 J
    Component: KSG H10 0080
    Coding: 1980202002186F0985054C9FC637
    VCID: 438371CC02C3B95286-8016
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Subsystem 3 - Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    1 Fault Found:
    01134 - Alarm Horn (H12)
    000 - -
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
    Part No SW: 8P0 959 802 J HW: 8P0 959 802 J
    Coding: 0004856
    2 Faults Found:
    00097 - Front Passengers Central Locking (Safe) Motor (V162)
    00929 - Locking Module for Central Locking; Front Passenger Side (F221)
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 186 G HW: 8P0 035 186 G
    Component: R Concert2+ H17 0240
    Revision: 00H17000 Serial number: AUZ1Z3G9141505
    Coding: 0730301
    1 Fault Found:
    00857 - CD Changer Unit (R41)
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 112
    Mileage: 204547 km
    Time Indication: 0
    Date: 2019.01.03
    Time: 12:00:56
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
    Component: Tuer-SG H04 0040
    Coding: 0000216
    Shop #: WSC 06314 000 1012544
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
    Coding: 0000216
    Address 76: Park Assist Labels: 8P0-919-283.lbl
    Part No SW: 8P0 919 283 D HW: 8P0 919 283 D
    Component: Parkhilfe 4-Kan H09 0070
    Revision: 00H09000 Serial number: 00067824820719
    Coding: 0000013
    Shop #: WSC 131071 1023 2097151
    VCID: 3C710A307F3DC6AAC7-8068
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 K HW: 8P0 862 335 K
    Component: FSE_255x BT H26 0340
    Revision: 00000000 Serial number: 00000005216553
    Coding: 0001222
    VCID: 3E7500386921D4BAE9-806A
    End-------------------------(Elapsed Time: 01:53)--------------------------
  7. Re: Help required - Audi A3 8p
    May 2016
    Bromsgrove
    I haven’t blocked the vin
    Since this scan I have installed the new cluster
    Abs problems all sorted
    I just need to somehow extract the pin from the new cluster and code to the car
    I also need to turn immob back on
  8. Re: Help required - Audi A3 8p
    May 2016
    Bromsgrove
    Hoping all goes well I have someone coming tomorrow to code the instrument cluster he says he has to do it online to Audi? Either way I’ll let you know
  9. Re: Help required - Audi A3 8p
    Oct 2014
    East Londonz
    Quote Originally Posted by adgti View Post
    Yeah you have some coding issues which will need to be done on line via Audi connection. Let us know how you get on.
  10. Re: Help required - Audi A3 8p
    May 2016
    Bromsgrove
    All issues sorted apart from coding the new instrument cluster, with the old cluster connected the immo had a fault stored rom error that wouldn’t clear but with the new cluster that has gone. Abs all sorted and the other faults gone.
    thanks for your help though I’ll reply tomorrow
  1. New Key Required: 2013 Audi A4
    By m33ufo in forum Parts & Accessory Price Requests
    Last Post: 06-09-2017, 12:06 AM
  2. Replies: 16
    Last Post: 24-11-2016, 01:28 PM
  3. VAG Tacho 2.2 help required - Audi TT
    By apowar in forum VCDS - General Questions
    Last Post: 05-05-2008, 02:37 PM
  4. Audi 80 B3 1.8 Gearbox, Help Required
    By Knightkiller in forum 80 - 90
    Last Post: 04-02-2007, 03:42 PM
  5. Audi 80 Advant - Help required!
    By diamondbrit73 in forum 80 - 90
    Last Post: 18-01-2007, 11:41 PM
