Thread: Dash cam hard wiring help
  1. Question Dash cam hard wiring help
    Jan 2019
    Peterborough
    I have a 2017 Passat Estate R-line
    It says in my hand book that the fuse box is behind the glove box and you need to push the side strut back to drop it down can't see how to do this tho?
    Also how did you get the cables down the windscreen side pillar? Can this be taken off some how?
    Also has anyone got a cable from the front to the back window. I have a dash can with a rear camera that a cable needs routing some how, my car has the parametric sun roof as well.
    Any info would help
    thanks
  2. Re: Dash cam hard wiring help
    May 2018
    Devon, UK
    Quote Originally Posted by jdobson1999 View Post
    That bit I can help with: you push the strut in the opposite direction from the picture in the manual!
  3. Re: Dash cam hard wiring help
    Jan 2019
    Peterborough
    Thanks that worked.
    I've added a few picks of the strut and the hole behind.
    Also added one of the fuse box with the Fuse adaptor using the cigarette fuse if anyone interested.
  4. Re: Dash cam hard wiring help
    Feb 2019
    Basildon, Essex
    Hi, I have recently bought exactly the same car (R-Line Passat Estate 2.0 TSI, 2018 model) and have the same issue releasing the glove box to get to the fuses!
    From your photo it looks like there is a large washer which appears too big to go through that hole?
    I'm still struggling!!
  5. Re: Dash cam hard wiring help
    Dec 2018
    GB
    Quote Originally Posted by UKFlyer View Post
    You see the black lowering support, when the glove box is in the down position pull the support towards you, it's moves a few mm and then pops out
    Sent from my Pixel 3 using Tapatalk
  1. Hard wiring for a dash cam
    By bingodingo in forum A7 - S7
    Last Post: 25-02-2016, 11:21 PM
  2. Has anyone hard wired a dash cam in an a6 ?
    By craigh9916 in forum Retrofits
    Last Post: 08-02-2016, 10:52 AM
  3. Question hard wiring
    By sh4m41l in forum Golf MK4 - 1999 - 2004
    Last Post: 23-02-2010, 10:03 PM
  4. Garmin SatNav and hard wiring...
    By webchem in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-06-2007, 05:30 PM
  5. Hard Wiring A TomTom SatNav
    By TheDufster in forum Passat - Archive Topics
    Last Post: 02-01-2007, 06:54 PM
