Thread: Vw crafter 2.0 timing belt
  1. Vw crafter 2.0 timing belt
    Jan 2019
    Bham uk
    Driving low speed about 10mph heard a short low scraping type sound and engine stalled. I tried it couple of times then called recovery. They inspected timing belt and said top wasnt moving while trying to start engine . Put it down to timing belt problem. Is it possible a timing belt/pump replacement is worth a try or is it more likely that the valves and pistons are damaged . Also is it possible theres another potential fault causing the problem ?
  2. Re: Vw crafter 2.0 timing belt
    Dec 2018
    Scottish Borders, Scotland
    If it has snapped the belt then there is usually always damage to the top end requiring a head rebuild unfortunately. Hard to diagnose without actually seeing the vehicle though
  3. Re: Vw crafter 2.0 timing belt
    Jan 2019
    Bham uk
    Thanks .. The belt didnt snap and i couldnt actually see damage to it but the cover wasnt completely removed . He just said top wasnt moving when turning ignition
  1. Audi A6 2.7 tdi Timing chain or timing belt?
    By AigarsH in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-12-2018, 10:08 AM
  2. Vw crafter timing ring/crank oil seal
    By LewisHE1981 in forum New Member Introductions
    Last Post: 08-07-2018, 11:23 PM
  3. Replies: 4
    Last Post: 29-04-2014, 04:47 PM
  4. Question 2006 1.6 FSI SE - Timing Belt or Timing Chain?
    By wddonalds in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2010, 05:44 PM
  5. Changing the timing belt and drive belt on Audi A6
    By Robbromilow in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-09-2009, 08:00 PM
