Thread: CarPlay for MMI 3G 4G RMC
Page 5 of 5 FirstFirst ... 345
Results 41 to 48 of 48
  1. Re: CarPlay for MMI 3G 4G RMC
    #41
    Jun 2015
    Ireland
    51 Post(s)
    Quote Originally Posted by Majonda View Post
    If I’m using sat nav and have car radio in back ground the MMI knob interferes with radio and changes station
    That is correct if you MMI radio. I use TuneIN internet radio from the phone and dont have that issue. TuneIN does all the stations around the world and its a CarPlay supported app.
    2015 A6 S-line Black Edition 2.0 TDI ULTRA
    MODs: CarPlay with RMC, Ambient Lighting
  2. Re: CarPlay for MMI 3G 4G RMC
    #42
    Feb 2019
    Ire
    Iíve been using tune in also but I find this to be sporadic also...
    It tends to defer to CarPlay Audio instead of phone Bluetooth
  3. Re: CarPlay for MMI 3G 4G RMC
    #43
    Jun 2015
    Ireland
    51 Post(s)
    I’ve been using tune in also but I find this to be sporadic also...
    Yeah, that happens. I noticed that if you connect the cable before the bluetooth connects then it chooses bluetooth... works 8/10
    It's not perfect, I agree but it really ticks all the boxes for me.
  4. Re: CarPlay for MMI 3G 4G RMC
    #44
    Feb 2019
    Ire
    Do you have similar issues with Satnav ?
  5. Re: CarPlay for MMI 3G 4G RMC
    #45
    Jan 2020
    Hungary
    Quote Originally Posted by artheb View Post
    Here are the steps I took in order to install the CarPlay
    This is the video I followed. I didnít have any panel tools so I used my kids plastic spoon and knife to pop out the aircon panel.
    Wireless Apple CarPlay Retrofit for Audi A6 A7 C7 MMI 3G - YouTube
    Connection diagram
    My additional comments.
    Please note that after removing the MMI unit , it will trigger the airbag fault which needs to be cleared with VCDS when you put it back together. It happens when you disconnect the passenger off airbag notification.
    1. If you want to use AUX, then you need to replace the green connector block on the 48 harness
    2. If you use AMI connection then no need to change the green connector block
    3. MMI control- You need to connect the blue cable from the CarPlay to the yellow white cable from the 48 harness. For RMC it is connected in the different block on the 48 harness but itís an only one yellow white cable so you cannot make a mistake.
    4. Unit comes with the dedicated microphone. I donít use it but I installed it in the panel above the head.
    I used my catís toy to push it behind the ceiling and behind the airbag on the pillar.
    I ran the cable underneath the seal on the pillar and behind the glove box which also needs to be removed in order to place the CarPlay unit.
    5. CarPlay unit I placed behind the glove box. There is some space to place it. Cables can be pushed from the MMI through the small gap. Itís pretty easy.
    6. CarPlay USB is currently located in the glove box. There was a blanked whole which I used to run the cable from the CarPlay which is just behind the glove box.
    My hacks.
    I wasnít happy with the performance of the wireless CarPlay so seller asked me to try the cable CarPlay. It works very well and charges the iPhone. Iím good with that. Iím a network engineer and I prefer cables anyway.
    Audio hack
    I keep my phone connected to the original MMI Bluetooth. That way I keep all the regular MMI behaviour of the phone calling + CarPlay enhancements and I donít need AMI or AUX cables .
    On the phone I configured it to force the Bluetooth speaker for the phone calls.
    Settings->general->accessibility->call routing
    MMI media is set to my phone as a music streaming device. That way Apps send audio back to the MMI. I use Spotify and tunein. Sometimes you need to manually change the app to use Bluetooth as an audio output. Happened twice so far. Not a big deal.
    I ordered AMI aux cable anyway just to see how would that work but donít think I will use it.
    Those are my findings so far. Lack of touch screen is not an issue at all. All MMI controls work very well.
    Some photos
    hi!
    i have a a6 facelift with rmc.
    but the rmc head unit dont't have green connector.
    only pink and yellow...
    from the carplay unit come a green cable..
    this connected to the pink or the yellow connector??
    thank you!
    Balazs from Hungary
  6. Re: CarPlay for MMI 3G 4G RMC
    #46
    Jun 2015
    Ireland
    51 Post(s)
    Quote Originally Posted by greycat View Post
    hi!
    thank you!
    Balazs from Hungary
    Canít remember exactly but I think it was yellow wire in the blue block connector
  7. Re: CarPlay for MMI 3G 4G RMC
    #47
    Jan 2020
    Hungary
    thank you!
    Shared album - Bal√°zs Varga - Google Photos
    i linked a photo from rmc...
  8. Re: CarPlay for MMI 3G 4G RMC
    #48
    Jun 2015
    Ireland
    51 Post(s)
    thank you!
    I thought you are talking about different connections. This should help.
    Retrofit RMC to MIB2 - AudiWorld Forums
  1. Retrofit CarPlay
    By AngryBunny in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 10-06-2019, 06:57 AM
  2. iOS 12 and Carplay issue
    By gebbel in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 19-09-2018, 04:32 PM
  3. Q for this with Apple CarPlay
    By a900ss in forum Passat - B8 Forum - 2015 -
    Last Post: 05-05-2018, 07:19 PM
  4. Issue with CarPlay
    By MacUsers in forum Q7 - 4M Forum - 2016 -
    Last Post: 24-03-2018, 11:21 AM
  5. Question How do I get CarPlay to work?
    By andybanksuk in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-10-2016, 09:34 PM
