Thread: outer pad ware
  1. outer pad ware
    Aug 2014
    uk
    brakes done about a year, year and half ago, new rear disks and pads
    the off side rear outer pad is now to the metal..
    the hand brake arm is returning fully, dont think its sticking or cable
    the sliders and moving freely
    the pads were alittle tight on the carriers, prised out with a screw driver.
    am thinking its either the after market pads have been to tight or the caliper piston. but if the caliper was at fault, wouldnt that mean more inner pad ware than outer?
  2. Re: outer pad ware
    1841 Post(s)
    Failed calipers, a constant PQ35 platform problem, the thing is WHY is it nearly always the right hand side, we like to do both just in case.
  3. Re: outer pad ware
    Aug 2014
    uk
    Aye caliper was seized. Only done the one side.
    After clamping the brake line , I shouldn't need to bleed brake right ?( Edit: yes I need to bleed lol. Did I really ask that ?)
    Edit , best way setting up caliper / hand brake .. few pumps of brake pedal then apply hand brake ?
  4. Re: outer pad ware
    1841 Post(s)
    Pump the pedal, operate the handbrake, int olde day we add tu use feeler gauges!
  1. Please Help Brake ware Sensor
    By Zimjason in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-03-2018, 12:42 PM
  2. 2.5 TDI Camshaft ware
    By quattrogary in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-03-2011, 09:26 PM
  3. Important outer cv joint
    By tbs in forum Golf MK4 - 1999 - 2004
    Last Post: 10-02-2011, 04:01 PM
  4. Please Help b5.5 tyre ware
    By jonathan bees in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-05-2010, 01:57 PM
  5. VAG COM & soft ware...
    By scootermap in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-02-2010, 06:15 PM
