Thread: Central Locking Issue
  1. Central Locking Issue
    Oct 2018
    Barnstaple UK
    Just wondering if anyone could shed any light on this before I go spending money.
    I have noticed that the drivers rear door will not open from outside once unlocked so I think I need a new door lock but now I have noticed that the fuel flap will not open now. I know it has a separate lock for the flap but just wondering if they are linked in some way so that if I replace the door lock it will work or should I get the flap lock also.
  2. Re: Central Locking Issue
    Oct 2012
    Estonia
    64 Post(s)
    No, those are not linked...you need to replace both...
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  3. Re: Central Locking Issue
    Apr 2009
    On my 1998 polo the fuel flap and boot are linked and both are locked solid ...the rear passenger doors whilst they will open the buttons are tight to pull up
    The central locking vacumn pump has failed and iuntil i can find a replacement i am stuffed
    As for the door locks and handles they were difficult a few years ago but heavy dose of silicone spray NOT wd40 solved that ...its worth a try
  4. Re: Central Locking Issue
    1836 Post(s)
    The 8K and other contemporary Audi fuel filler flaps are almost (not quite) as big a reliability joke as 8P rear wiper motors.
    Despair, the Audi A4 type 8K uses a computer controlled electronic central locking system, your Polo 6N1 uses a electro pneumatic system operated by a pump under the right rear light unit, you would be far batter served to start a new thread in the Polo 6N section.
  5. Re: Central Locking Issue
    Apr 2009
    Thank you ...do you not think i have been trying to find the Polo section on your forum ?
    Its one of the most convaluted and dastardly forums i have ever found or maybe it simply is only designed to work on Apple!!
  6. Re: Central Locking Issue
    May 2016
    Dublin
    I had the same problem with the drivers side door, the passengers side door, and now the rear left one is acting up too.
    I fixed the drivers originally by replacing the door lock. This was pricey at 90e per module, and it only lasted for a couple of months until I got the same problem again. So I opened it up and found that the commutator on the motor was in need of a good clean. Once I did that to all the dodgy modules they started working again, and have been working well for nearly a year now.
    I wrote up a guide on how to do it here. Warranty Void: Repairing Audi A4 B8 8K door not unlocking with remote fob
  7. Re: Central Locking Issue
    1836 Post(s)
    Quote Originally Posted by despair2 View Post
    Here Sir for your delectation and advancement Polo - Derby - Lupo - Fox
    It could do with some sub division though....
    posted from my Apple iPad 2 air..............
  1. Central locking issue
    By Nottmman76 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 12-02-2021, 05:49 PM
  2. central locking issue
    By Anze in forum Golf MK4 - 1999 - 2004
    Last Post: 06-04-2015, 03:43 PM
  3. Please Help Central Locking issue
    By Ashdatta in forum Golf MK5 - 2004 - 2009
    Last Post: 05-05-2009, 03:32 PM
  4. Central locking issue
    By holly.arnott in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-02-2009, 06:48 PM
  5. Central locking issue
    By pg20 in forum Octavia
    Last Post: 27-06-2008, 08:35 PM
