Thread: Windscreen wiper arc adjustment
  1. Windscreen wiper arc adjustment
    Jul 2017
    Portsmouth
    Hello,
    My 66 Passat estate has just had it's windscreen changed and with that i changed the wipers, now the wiper catches on the side trim ('A' post) of the windscreen (they wipe to far). How do you adjust the swept arc? I took it in to the main dealership when i first got the vehicle as it was doing this back then, it took less than 5 mins, shame i never seen what he done? Now outside of warranty, don't fancy pulling the arm off and rotating slightly!
    Thanks in advance for any help
    Chris
  2. Re: Windscreen wiper arc adjustment
    May 2008
    Quote Originally Posted by Chaff900 View Post
    Hello,
    Chris
    Still within its 3 year warranty.
  3. Re: Windscreen wiper arc adjustment
    Jul 2017
    Portsmouth
    Hi Jim,
    Ive done over 60k miles now so i thought it would be outside of warranty!
  4. Re: Windscreen wiper arc adjustment
    May 2008
    Hi Jim,
    Ah okay, you are high mileage, in that case my simple answer is of no use to you!
  5. Re: Windscreen wiper arc adjustment
    Feb 2017
    Dunstable UK
    Hi Chris,
    My 16 Passat estate has had exactly the same problem from new. Mentioned it to the dealer when I had my first service and they have made it worse. Not the sort of thing you would expect from German engineering.
  6. Re: Windscreen wiper arc adjustment
    Dec 2018
    GB
    Hello,
    Chris
    Raise the bonnet, take the cap off whichever wiper you need to adjust, undo the nut and you will see the wiper is on a spline, lift and reposition a a couple of splines lower and obviously replace the nut and cap
    Sent from my SM-G955F using Tapatalk
  1. Windscreen jet adjustment????
    By Chrisman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-10-2010, 08:11 AM
  2. Avant rear wiper adjustment?
    By vma99r in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-08-2009, 09:07 PM
  3. Windscreen washer spray adjustment
    By clarkejw in forum Golf MK5 - 2004 - 2009
    Last Post: 04-12-2008, 09:23 PM
  4. Rear wiper stroke adjustment
    By g4rr3tt in forum Golf MK4 - 1999 - 2004
    Last Post: 02-05-2008, 04:04 PM
  5. Wiper Arm Adjustment & Radio Change
    By gazza007 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-09-2007, 12:49 PM
