Thread: 2005 Polo Front Sub-frame Bolts Loosening
  1. 2005 Polo Front Sub-frame Bolts Loosening
    Dec 2018
    Dorking
    I have a 2005 Polo 1.4 and the front sub-frame bolts keep loosening and then I get a clunking when I break or accelerate
    Does anyone know a solution or upgrade that might help me with this problem.
    The car only has 35K on it and other than this issue drives really well.
    All help is much appreciated
  2. Re: 2005 Polo Front Sub-frame Bolts Loosening
    Feb 2016
    manchester,uk
    14 Post(s)
    It would if you can put a picture on here.
  3. Re: 2005 Polo Front Sub-frame Bolts Loosening
    1836 Post(s)
    It is common to see the aluminum consul bolts keep coming loose when work has been done, such as new consul bushes, and then the old bolts used. The bolts are strictly one time one TTY (Torque To Yield) and an example is the M12 consul bolts where the spec is 70Nm plus a 90 degree turn to stretch. Even if a bolt is brand new, once it has been stretched it is junk and must be replaced, consequently we do not apply the stretch until we are sure everything is perfect and the alignment has been done, we have to keep a huge stock of genuine bolt, literally thousands of pounds worth but being stuck for a bolt can cost hundreds of pounds in dead lift time.
  1. Polo 1.2 2006 front strut mount bolts
    By warptechno in forum Polo - Derby - Lupo - Fox
    Last Post: 16-02-2016, 11:31 AM
  2. Sub-frame bolts & spacers
    By RichardSEL in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-05-2013, 10:14 AM
  3. Front sub frame loose?!
    By g-black in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-02-2011, 03:37 PM
  4. Front frame replacement
    By rained_mob in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-07-2008, 10:49 AM
