Thread: The dreaded " stop/start fault" message...
  1. The dreaded " stop/start fault" message...
    Mar 2015
    Twickenham
    Message popped up on Friday - engine management light came on, too, and remains on at all times. Car drives fine but the stop/start function stopped working. Q: the car is due a major service in 2k miles, which will be approx end of January/beginning of Feb, do I wait until then to get it fix, or should I get it seen now? I've got a trip to France planned over the festive period so slightly concerned, although unlikely that my local Audi Dealer will be able to booked me in until January...
  2. Re: The dreaded " stop/start fault" message...
    1837 Post(s)
    Why is it dreaded? It can be as simple as not fastening your seat belt although god knows why that is.....
  3. Re: The dreaded " stop/start fault" message...
    Jan 2013
    Wessex. and Southern France
    109 Post(s)
    get it checked, £60.00 for a buzz through the computer system may just put your mine at rest.
    0 0 1
  4. Re: The dreaded " stop/start fault" message...
    Jun 2015
    Ireland
    69 Post(s)
    Are you getting any other faults like abs, cruise control? That could be just faulty abs sensor.
    current: 2019 A6 S-Line 40 TDI Avant (de-chromed)
    sold: 2015 A6 S-line Black Edition 2.0 TDI ULTRA
    MODs: CarPlay with RMC, Ambient Lighting
  5. Re: The dreaded " stop/start fault" message...
    Sep 2009
    Broxburn
    I had asc abs / stopstart / parking brake all come up had it checked and found out it would cost 5,000 to fix...… huge job...….
    relax - it was an abs wheel speed sensor - under 100 to fix. trouble is cars are a heap of sensors these days
    2014 Andi 3.0 V6 TDi S-Line Quattro
    Full LeatherIHeated SeatsIElectric SeatsISunroofIMatt Brushed Aluminium InlaysIBi-Xenon HeadlightsIRear Park AssistIBluetooth
  6. Re: The dreaded " stop/start fault" message...
    1837 Post(s)
    Quote Originally Posted by ruggedscot View Post
    And it is going to get worse, much worse...
  7. Re: The dreaded " stop/start fault" message...
    Mar 2015
    Twickenham
    £710 later fault fixed by Audi Garage. The problem was a faulty throttle valve J338. Part replaced and all back to normal now. Thanks goodness to the extended warranty...
    1 1 0
  1. "Start/stop system deactivated you should start your engine manually"
    By AT. in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 31-08-2017, 09:19 PM
  2. Replies: 5
    Last Post: 23-01-2017, 11:11 PM
  3. Please Help The dreaded "Oil Sensor Workshop" warning
    By adamski69 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-10-2010, 07:10 PM
  4. FEEDBACK REQUIRED - "Start - Continue - Stop"
    Last Post: 15-06-2007, 11:47 PM
