Thread: Right xenon fault
Results 1 to 10 of 11
  1. Right xenon fault
    Dec 2015
    London
    13 Post(s)
    Got this msg whilst driving yesterday
    VCDS says below
    Any words of wisdom at all?
  2. Re: Right xenon fault
    Aug 2013
    Dalry - Ayrshire-Scotland
    30 Post(s)
    Are the lights/lamp working normally?
    I got a similar light a few months back for one of the rear led indicators ... it wasn’t working/light was out; recirculated ignition and it was back to normal...working fine with no warning on dash ( I haven’t done an error scan right enough..) I just put it down to an intermittent gremlin etc
    A6 Black Edition - 2014 - 2.0 TDI Manual
    Daytona Grey Pearl, Full LED Headlights, Technology Pack, Advanced Key
    4 Zone Climate Control & Heated Seats, Colour DIS, Lighting Pack - LED Ambient Lighting.
  3. Right xenon fault
    Dec 2015
    London
    13 Post(s)
    Light is out cold. Hope it's just the bulb. Seems impossible to reach the harness to even pull the connector out to see etc.
  4. Re: Right xenon fault
    Aug 2013
    30 Post(s)
    Ah missed it was a xenon bulb.. if it’s just bulb then surely straightforward. ( I was thinking led light fault etc)
    Hopefully be able to find instructions how to swap out bulb online/ on here etc..
  5. Re: Right xenon fault
    1840 Post(s)
    M31 is the Service Diagnose Code (SDC) for a standard incandescent non gas discharge light, the gas discharge bulb is L14 and dipping is by a screen motor V295 so this car has standard incandescent lights, not Xenon/HID oncoming traffic blinders. It is an H7 bulb. You gain access to the back of the headlight after jacking the car up, removing the wheel and removing the access panel in the arch liner, if it has the access panel, if not you have to remove the complete liner.
    Isn't it nice that his car is sending him a Kiss, so sweet....
  6. Re: Right xenon fault
    Aug 2013
    30 Post(s)
    This forum rocks.. cheers Crasher
  7. Re: Right xenon fault
    Dec 2015
    London
    13 Post(s)
    Lol more like it's indiscriminately winking at all oncoming cars right now
    Challenge is also the car is booked for MOT on Monday at the dealership. Guess I'll end up paying a premium as there's no time to DIY it.
  8. Re: Right xenon fault
    Jul 2016
    Chestfield kent
    81 Post(s)
    Halfords ?
    2015 FL S-line 2L ultra & 2003 225 TT Coupe
  9. Re: Right xenon fault
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    It takes 10mins to change the bulbs, you don't have to remove the wheel, if its drivers side bulb out put it full lock left, it'll give you enough room but its going to be fiddly. Your going to need some torx drivers, think its T25 for the access panel and something like T10 for the screw that holds the bulb in.
    Its easier if you remove wheel but its not necessary. Good luck for MOT
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
    1 1 0
  10. Re: Right xenon fault
    1840 Post(s)
    We do it with the car in the air and wheel off as it is less struggle.
  1. Xenon headlight fault - help please??
    By timhs in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-07-2016, 10:33 AM
  2. Please Help DPF pressure Sensor fault & Xenon Range Fault
    By jkuk1 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-11-2013, 03:17 PM
  3. Bi Xenon Headlight Fault
    By k6rff in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 31-08-2010, 12:25 PM
  4. HID Xenon ESP ABS Handbreak fault lights come on
    By thomswalwell in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-01-2010, 07:35 PM
  5. Xenon Headlight Fault...??
    By rick_1981 in forum Audi A3 - Archive Topics
    Last Post: 23-12-2008, 10:48 PM
