Thread: 2005 3.0tdi Qu C6 tip
Results 11 to 20 of 24
  1. Re: 2005 3.0tdi Qu C6 tip
    Aug 2016
    Cape Town, South Africa
    Looks good. Did you manage to get the new ones in all ok? Make sure the sleeves are home?
    2006 A6 Avant 3.0 TDi Quattro
  2. Re: 2005 3.0tdi Qu C6 tip
    Nov 2014
    Uk
    Hi zit
    The sleaves are for a different version, Im back to square 1 im trying to locate that version I have, Iv found the adapter seal but not the sleaves and the company cant help with locating them so Iv tried another ZF supplier
  3. Re: 2005 3.0tdi Qu C6 tip
    Aug 2016
    Ah, that's a pity. Did you get given the BMW ones? Such a common assumption by the ZF parts suppliers. Are the ones you were given profiled as opposed to just being pieces of tube?
    I believe the part numbers you want are:
    0734 317 389 - Sealing Sleeve (3x)
    0734 317 370 - Sealing Sleeve (1x)
  4. Re: 2005 3.0tdi Qu C6 tip
    Nov 2014
    Uk
    Hi zit,
    I have found the sleeves in the netherlands so Ive ordered them, would you advise replacing the valve body separator plate as the transmission is in bits already, Also should I send the mechatronic away to be tested/repaired,
    I still dont think what I'm doing will fix it I think its more serious like the pump or a seal which requires transmission being removed,
    Is the oil at the end of the transmission the same or is it like a transfer type oil,
  5. Re: 2005 3.0tdi Qu C6 tip
    Aug 2016
    I don't think doing the separator plate is worth it. I would do everything you already planned to do (sleeves, solenoids, bridge seal, new fluid) and see if that helps.
    I tend to also think you have something more sinister going on, but lets hope it was a passing sleeve or a leaky solenoid. I wouldn't go mechatronic rebuild yet.
    The oil in the torsen/centre/transfer diff is a fairly exotic concoction. Well, it's actually just diff oil which has a very exotic additive in it. Having said that I just put in Ravenol limited slip diff oil and that cured my torsen rumble and I haven't had any issues.
    The ZF workbook I recommended discusses the various oils.
  6. Re: 2005 3.0tdi Qu C6 tip
    Nov 2014
    Uk
    Hi Zit,
    The sleeves wont arrive until the 4th of Jan so no undates until then, can you list the correct oils so if anyone is following the progress they can refernce back to this like I have, do you know much about this adaption reset ive heard it mentioned on youtube but not found how or what it means
  7. Re: 2005 3.0tdi Qu C6 tip
    #17
    Aug 2016
    Hey N19.
    Sorry for the late reply, I'm in the middle of moving from Joburg back to Cape Town and packing is a mare.
    I'll consilidate a list of oils and ATF's for the box for you this coming weekend.
    In terms of the adaption reset, don't let anyone tell you some garbage about holding down the accelerator, turning the ignition on and off, etc. If anything, that just resets the position of the DBW throttle.
    To actually reset the clutch adaption charge times and pressures, you need to go into VCDS, into the transmission, then to adaptions. Then scroll to adaption 01, and save a 0 there. Then to confirm that they're reset, go to measure blocks values 73-77, which correspond to clutches A through E. After a successful reset, all these values should now be 0.
    Then it's time to perform an adaption drive, and certainly hold off the heavy throttle for a while as the box is still learning how to only allow the clutches to slip an acceptable amount.
    SSP385 explains very well the actual adaption phases. Very clever and the box is actually adapting the unused clutches whilst in certain gears. You can actually feel the pulses whilst it's doing it.
  8. Re: 2005 3.0tdi Qu C6 tip
    #18
    Nov 2014
    Uk
    Hi Zit
    Ive put the new sleeves etc back in refilled with oil started it refilled again theres about 5ltrs in there roughly, Put it in drive and reverse still no drive
    it looks like I will be removing the gearbox to repair it, what do you think it is seal, bush or pump what should I start looking for,
  9. Re: 2005 3.0tdi Qu C6 tip
    #19
    Aug 2016
    Hi N19,
    That's a pity that quick fix didn't work, but as I suspected, there's something more serious going on. Either loss of pressure due to a bad pump, passing valve or seal/bush, Or some other failure. I'm certainly no expert on the internals of the 6HP19A. I can't be certain if your issue is mechatronic or clutch related. If you do want to have a go at stripping yourself, then firstly setup a nice big clean comfortable work environment, then watch all the 6HP19 video's on youtube. There are some good ones.
    I would still recommend getting a specialist involved at this stage though, unless you can do without the car for some time. Perhaps even look for a second hand transmission of the same code. That may well be a better route to go.
  10. Re: 2005 3.0tdi Qu C6 tip
    #20
    Nov 2014
    Uk
    Hi Zit,
    I thought the same as you the night it failed its lost the pressure going by the youtube vid id say its that comon failure E clutch is it you mentioned at the beginning even ZF pdf mentions comon fault due to a single seal or somthing like that, what does the seal look like and bush or an Oring
    Can a diagnostics machine show any of the pressures etc in the gearbox , put a manual box in
    As for the car sitting in the shed for a few months doesn't matter
  1. 2005 A6 C6 3.0Tdi De-cat
    By spottedhaggis in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-08-2018, 10:31 AM
  2. Please Help A4 2005 b7 2.0tdi SICK..
    By chilli76 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-09-2015, 08:56 PM
  3. 2005 audi a4 2.0tdi
    By vinny63 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-10-2013, 07:58 AM
  4. 2005 audi a4 2.0tdi
    By vinny63 in forum VCDS - General Questions
  5. Please Help 2005 A4 2.0Tdi not starting
    By martybutler in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-06-2010, 12:36 PM
