Thread: BXE 1.9 TDI engine failure
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 64
  1. Re: BXE 1.9 TDI engine failure
    #21
    Mar 2008
    Hi guys, replaced my big end bearings with genuine ones and also replaced the bolts at the same time, surprisingly the shells were showing very little wear even the uppers, they didn't have any signs of brass coloured material or much wear, they were still the older part number so replaced anyway this was at 68k
    Filled with quantum longlife 3 and will keep to fixed service intervals
    Thanks for all the advice
  2. Re: BXE 1.9 TDI engine failure
    #22
    Oct 2017
    London
    12 Post(s)
    I’ve changed about 10 bxe engines this year. Interestingly I’ve only just seen my first 09 failure in a Passat estate. The rest are all 07/08 and never bkc engines ( found roughly in 05/06 cars) Mileage in the engine failures I’ve seen vary from 85k to 130k and some with a full history and some with no history.
    The bxe comes in all the vag range and fail in seat alteas all the way through to the vw touran. The touran used the bxe up to 2010 where the golf seems to have got rid of it late 08 early 09
  3. Re: BXE 1.9 TDI engine failure
    #23
    1840 Post(s)
    It is longlife servicing that is to blame, change the oil every 9300 miles, replace the bearings at 100k and they don’t fail, of our customers I have never seen a single failure.
  4. Re: BXE 1.9 TDI engine failure
    #24
    Oct 2017
    London
    12 Post(s)
    Most with the BXE are reluctant to change the bearings as the engines second hand are so cheap. Most leave it to chance and stick to the service. Different story with the BLS engine though. Very rare I see a BXF. Maybe once in 4 years and it had failed.
  5. Re: BXE 1.9 TDI engine failure
    #25
    Mar 2008
    Jon44w have you had any bxe engines fail that have had Conrod bearings and bolts replaced previously? Are the bearings bad in the bxe engine failures you see? Ive replaced my bearings and bolts with the latest genuine parts but there wasn't much wear on any of the bearings on the top or the bottom, the bearing part number had changed from an A which I had and the new ones were B for the top bearing though, my old bearings didn't look like all the ones posted that show the top ones a bronze colour, they were pretty good
  6. Re: BXE 1.9 TDI engine failure
    #26
    1840 Post(s)
    If it has some miles on it I would say it has either been exceptionally well maintained with 5K oil changes or the bearings have already been done. Every car I have done them on has had worn uppers. I have myself never seen the failure anyway either done or not.
  7. Re: BXE 1.9 TDI engine failure
    #27
    Oct 2017
    London
    12 Post(s)
    I don’t pay much attention to the bearings on the scrap engine but I will have a look the next time and post on here.
    I doubt they have been replaced as there is no sign in the service book or receipts of any of the cars ever having it done. That I do check.
    The reason crasher has never seen a failed engine is because his customers are replacing their bearings. A job which he has done many times and I haven’t. It can’t be a coincidence then that I have then replaced engines many times and he hasn’t.
  8. Re: BXE 1.9 TDI engine failure
    #28
    Jul 2021
    Monmouth
    Apoligise to bump this post
    What sort of labour time am I looking at for these to be replaced? I sold my 2017 Leon for a 2008 1.9tdi not knowing this issue, I don't drive often so a cheap run around! (when I do drive it's usually 30 miles ish distance)
    Only to find out about this issue, it's got 89k miles, full service history every 10k miles, but I have no idea what oil was used!
    My mechanical skills are no where near on par with this, I can do brakes at best!
    UK based
    Edit:
    Called my local 'go to' garage, they've never heard of this issue, so said they'd get back to me once they've looked it up (no vw specialist for approx 60 miles)
  9. Re: BXE 1.9 TDI engine failure
    #29
    Oct 2017
    London
    12 Post(s)
    Do you mean the labour time to change the bearings or to replace an engine? The bxe can go for 250k no problems if serviced every 9k with 5w/30. Saying that though I’ve seen some fail with a full proper history. Good job you didn’t go for the 08 BLS engine as you’d have no end of problems with it doing short drives and it’s throws the rod too and costs lots more than the bxe.
  10. Re: BXE 1.9 TDI engine failure
    #30
    Jul 2021
    Monmouth
    Hi, yes I mean for the labour to change the bearings, not the engine 😂
    I know someone with one on over 300k who has never had them done, but trust me, I'm cursed, if it can fail it will. Everything Ive ever owned cars, computers, phones, animals, something goes seriously wrong.
    I do long runs mainly, but only about once every 2 weeks for about 60 mile round trip. And then drive about once a week about 3 mile round trip to my grandfather's
    Edit:
    My local fast food delivery driver had a mk6 1.6tdi which gave her loads of problems, she's now got the '58'(2008) 1.9tdi mk5 bls engine, last year she done 35k, no problems whatsoever, it's on nearly 200k! And as you can imagen that's mainly short runs
  1. Please Help A4 B7 Engine ECU Failure
    By 27mart in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-06-2016, 09:38 AM
  2. bxe engine con rod failure
    By boidy in forum Golf MK5 - 2004 - 2009
    Last Post: 04-10-2014, 11:55 AM
  3. Please Help A4 2.0 FSI Engine Failure
    By roflynn in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-08-2008, 10:52 AM
  4. Please Help engine failure
    By steveg in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-06-2008, 10:51 AM
  5. Engine Failure
    By chuddleston in forum Audi A4 - Archive Topics
    Last Post: 13-04-2007, 05:17 PM
