Thread: BXE 1.9 TDI engine failure
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 64
  1. Re: BXE 1.9 TDI engine failure
    May 2012
    Everywhere
    308 Post(s)
    I think they have , but Crash Bang Wallop will confirm .
  2. Re: BXE 1.9 TDI engine failure
    1837 Post(s)
    No, the problem is and was the ridiculous long life oil change intervals combined with the low emissions oil; use long life 3 every 9000 miles and change the bearings at 100k miles and there is no problem.
  3. Re: BXE 1.9 TDI engine failure
    Mar 2008
    I think I'm going to replace the bearings and bolts now, use the longlife oil as suggested every 9k then forgot about it, I've just brought the car so can't confirm what oil has been used, it has service history but from not dealer, do I use the bolts from tps specified for this vehicle?
    Are there any known failures after the bearings are replaced?
    Thanks for the replies ��
  4. Re: BXE 1.9 TDI engine failure
    1837 Post(s)
    Yes, use the bolts TPS supply according to your VIN. I know Gaz incredulous when I say it but I have actually never personally experienced this failure on a customers car with or without new bearings but quite often we get asked to change them preventively and the upper shell is always heavily worn as in my picture earlier in this thread.
  5. Re: BXE 1.9 TDI engine failure
    Mar 2008
    Hi guys so I've got the bearings from tps, does it matter which way the sputter top bearings face as there's a black line on the one end, not sure if this meant anything? So I've found that the 701 B bearings are the top sputter ones and the 701 C are the bottom ones
  6. Re: BXE 1.9 TDI engine failure
    1837 Post(s)
    I have never used genuine bearings on these as I think they are too expensive but Glyco bearings go in either way.
  7. Re: BXE 1.9 TDI engine failure
    #17
    Mar 2008
    Do I need to make any crankshaft measurements or do people just fit the standard spec bearings ? I know I have brought the tps ones now and was just going to fit them ,The car has only
    done 68k so hopefully minimal crank wear
  8. Re: BXE 1.9 TDI engine failure
    #18
    1837 Post(s)
    Just get on with it!
  9. Re: BXE 1.9 TDI engine failure
    #19
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by mystic 8v View Post
    Just make sure the rod surfaces are BONE DRY before fitting the shell bearings then lube afterwards before reassembly. Best done off engine as in situ it is very difficult to ensure the shells are fitted dry into the rods. I did that once in my youth but never again as the poor Corsa had its crank chewed as the new shells got a tiny bit of oil in behind them and they had a dance around the crankshaft as a result!
    Mad Mitch
  10. Re: BXE 1.9 TDI engine failure
    #20
    1837 Post(s)
    Quote Originally Posted by DMitch16 View Post
    You spin me right round baby right round...
    1 1 0
  1. Please Help A4 B7 Engine ECU Failure
    By 27mart in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-06-2016, 09:38 AM
  2. bxe engine con rod failure
    By boidy in forum Golf MK5 - 2004 - 2009
    Last Post: 04-10-2014, 11:55 AM
  3. Please Help A4 2.0 FSI Engine Failure
    By roflynn in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-08-2008, 10:52 AM
  4. Please Help engine failure
    By steveg in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-06-2008, 10:51 AM
  5. Engine Failure
    By chuddleston in forum Audi A4 - Archive Topics
    Last Post: 13-04-2007, 05:17 PM
