Thread: Need help with 2003 Audi A4
Results 1 to 10 of 11
  1. Need help with 2003 Audi A4
    Dec 2018
    Hello I have a 2003 Audi A4 Quattro 1.8L turbo it’s the wagon. I have an unknown issue I need help figuring out what’s causing it. I have multiple misfires and believe I have a dead cylinder. I theorize it’s related to vacuum because the A/C and heat doesn’t blow only out of the defroster vent. I also have a very hard time idling it sounds rough and rpms spike down and engine lights starts flashig. Of course I assumed it was spark plugs so I already have replaced all plugs and the coil packs. I really am quite confused as to what else can cause this if you have any ideas please direct message me. Thank you!
  2. Re: Need help with 2003 Audi A4
    Nov 2008
    Leeming
    Try searching for PCV valve posts, sounds very familiar.
  3. Re: Need help with 2003 Audi A4
    Dec 2018
    That’s kinda where I was leaning towards I think it’s worth a shot replacing those appreciate the advice thank you. I will let you know if it fixes my problem.
  4. Re: Need help with 2003 Audi A4
    Nov 2008
    Leeming
    Try taking off your oil cap whilst car at idle, if you struggle its because of a vacuum caused by the crankcase breather valve.
    Valve is very cheap replacing the pipes connected to it when they crumble are not !!
    Last edited by blackpool1974; 07-12-2018 at 09:16 PM. Reason: didnt know what i was talking about
  5. Re: Need help with 2003 Audi A4
    Dec 2018
    Gotcha well let’s hope it’s not the pipes haha thanks.
  6. Re: Need help with 2003 Audi A4
    Nov 2008
    Leeming
    This is a fault i had a few years ago, the oil cap bit still stands, but it is the crankcase breather valve which i meant to say will be the culprit it does have a habit of causing PCV breakages and due to pressure in the manifold causing rocker cover oil leaks into spark plugs
  7. Re: Need help with 2003 Audi A4
    Dec 2018
    That looks very similar to a valve I just replaced however the valve was taken off of another Audi and could very well have been bad too
  8. Re: Need help with 2003 Audi A4
    Nov 2008
    Leeming
  9. Re: Need help with 2003 Audi A4
    Dec 2018
  10. Re: Need help with 2003 Audi A4
    Nov 2008
    Leeming
    Click the link, if I am right this is your problem, connecting car to VCDS will confirm straight away.
  1. 2003 Audi RS6 C5 cat back exhaust fitted to 2001 Audi allroad 2.5tdi
    By skyegtb in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-10-2016, 09:13 PM
  2. Replies: 0
    Last Post: 15-02-2012, 05:35 PM
  3. audi rns dx in a audi a4 cabriolet 2003 problems
    By williew in forum In Car Entertainment
    Last Post: 23-02-2009, 04:54 PM
  4. Will 2003 cabriolet leather seats from fit my audi a4 2003 b6 model?
    By audisingh in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-05-2008, 11:19 PM
  5. audi diagnostics plug on Audi A3 2003 -
    By alistairr24 in forum Audi A3 - Archive Topics
    Last Post: 30-08-2007, 06:45 PM
