Thread: Q7 4M - Trailer Assist - Do I need to lube the tow ball?
  1. Q7 4M - Trailer Assist - Do I need to lube the tow ball?
    Dec 2012
    Warwickshire
    Hi all!
    My Q7 4M is here and I paid a frankly extortionate £3,000+ to have the tow bar fitted with trailer assist enabled.
    This is all working simply superbly, and I have towed about 60 miles so far with it.
    However, something that occurred to me is that with the ring should I be lubricating the ball hitch? So far I haven't, I can see it's starting to rub some of the paint off... I plan on towing a heavy load several hundred miles in the New Year so wish to make sure i'm not oging to damage anything!
  2. Re: Q7 4M - Trailer Assist - Do I need to lube the tow ball?
    Feb 2016
    Blaydon, North east England
    32 Post(s)
    If your using an Alko hitch or another hitch with friction pads to stop snaking etc then do not lubricate it, you should also clean the paint off as it contaminates the friction pads.
    2015 A6 Allroad 218 - NEW
    2012 A6 Avant SE 3.0TDi Multitronic - OLD
  3. Re: Q7 4M - Trailer Assist - Do I need to lube the tow ball?
    Dec 2012
    Warwickshire
    Quote Originally Posted by KevTrem View Post
    Iím not using a hitch with friction plates. Just a plain old hitch.
    My query is due to the sensor ring & possible contamination of it
  4. Re: Q7 4M - Trailer Assist - Do I need to lube the tow ball?
    Feb 2016
    32 Post(s)
    Ah right, I'm not sure now then. As if using a normal hitch you'd expect to throw grease on there, but sensor ring may rely on friction with coupling to sense what trailer is doing. Have you had a look in your manual to see what it says in there?
  5. Re: Q7 4M - Trailer Assist - Do I need to lube the tow ball?
    Dec 2012
    Warwickshire
    I have had a look and it doesnít say.
    I might ring the dealer and see if they know (unlikely)
  1. Replies: 26
    Last Post: 12-10-2018, 02:47 AM
  2. Trailer assist TTA on A4 model
    By french_audi in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 24-01-2018, 06:08 PM
  3. Trailer Turn Signals Not Working - but Trailer not Connected
    By tidybutt in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 07-05-2009, 09:24 PM
  4. No lube on my top end!?
    By bengusmk1 in forum Golf MK1 - 1974-1984
    Last Post: 17-03-2008, 08:14 PM
  5. lube
    By southwest in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-05-2007, 07:30 PM
