Thread: 1.6 CAYC rough idle
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: 1.6 CAYC rough idle
    Nov 2020
    Derbyshire
    1.6 tdi 2009
    Rough idle wen cold Stalls, misfire
    seems to have a little miss fire wen warm,
    Limp mode
    glow plug light
    Had air mass sensor last week as I broke down would tick over but not generate any power, code was a
    mass or volume air flow circuit range / performance, Reset and replaced the valve no change,
    Back to the above symptoms
    New codes today
    P10100 mass or volume air flow circuit range / performance,
    P029900 turbo / supercharger under boost
    I fort the rough idle the stalling it was injectors,
    But with above codes I’m a bit lost,
    Any help is appreciated,
  2. Re: 1.6 CAYC rough idle
    1841 Post(s)
    You need to start your own thread AND most importantly have a proper VCDS code read carried out and post the results using the hashtag code code function in advanced reply. Where was the new Air Mass Meter bought from and do you know the part number?
  3. Re: 1.6 CAYC rough idle
    Nov 2020
    Derbyshire
    New one is a NTK, form TPS was not cheep, the original part number 03L90646- the car currently has no faults it’s just waiting till it throws a code to get a Vag report,
  4. Re: 1.6 CAYC rough idle
    Dec 2016
    Gävle, Sweden
    Quote Originally Posted by jake310890 View Post
    1.6 tdi 2009
    Limp mode
    glow plug light
    New codes today
    I had similar problems recently and the air mass meter code. It turned out to be a failing EGR cooler. And it eventually failed completely with the EGR valve flap falling of it's axle and the car didn't even start so it had to be towed.
    So I had the EGR replaced. Not very cheap because it's 4.5 hours of work for a professional. And then about £300 in parts (EGR cooler, gaskets, stretch bolts, etc). Now every symptom is gone except for the rough idle. I think that's because of one or two bad injectors.
  1. Pd tdi rough idle help
    By Caddy scott in forum The Commercial Range
    Last Post: 11-11-2016, 09:40 AM
  2. 06 Audi A6 2.0 TDI Rough Idle / Jumpy Idle
    By nizzex in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-11-2015, 07:53 PM
  3. rough idle
    By jmm86 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-07-2012, 11:27 PM
  4. rough idle
    By daddy5times in forum New Member Introductions
    Last Post: 30-04-2010, 10:08 PM
  5. Question A4 2.6 rough idle/rough at high rpm
    By teccyjim in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-09-2008, 07:22 PM
