Thread: 2004 A3 steering rack - different part number?
  1. 2004 A3 steering rack - different part number?
    Dec 2018
    Norway
    Hello.
    I own a 2004 Audi A3 3-door, and a while back I got the notorious “red steeringwheel” and the power steering was all gone. The following weeks it came and went but now it is dead all the time.
    I got the rack off the car, and plan to swap it for a second hand. And that leads me to my question: The white sticker on mine says “1K1 909 143L”, and next to the small Audi/vw-logo I think it says the same, but “J” on the end. (The sticker got beat up). How important is it that I get one with the exact same number? I found several online, amongst “1K1 909 144L” will that work?
    Second question: Does anyone know what usually fails on these? I work at a place that makes electronics, and might be able to fix it, if it’s an electrical error.
    Best regards
    Sindre
  2. Re: 2004 A3 steering rack - different part number?
    Jul 2010
    Monmouth, Wales
    7 Post(s)
    Have you actually had a diagnostic done? I would have thought it is more likely to be an electronic problem than the rack itself.
  3. Re: 2004 A3 steering rack - different part number?
    1836 Post(s)
    The rack numbers get VERY confusing, you will have a Gen 1 rack I guess and converting to GEN2 or GEN3 is not simple or cheap. 1K1 909 143L isn't actually a proper part number, it is an internal use number and the centre group starting with 9 indicates an electrical part, the rack number would be 1K2 (for right hand drive, 1K1 LHD), then 423 (steering gear) and 055 (specific variation) with any one of 20 or so single and double letter variations such as B , C, etc. The very latest number is 1K2 423 055 KX for a genuine exchange unit at £1312.75 BUT as I said, this is GEN3 and you will have conversion work to do.
  4. Re: 2004 A3 steering rack - different part number?
    Dec 2018
    Norway
    Called my local Audi dealer, and got some help.
    They said i can use any rack from A3 2004-2013.
    Bought a used 2010 with super low milage, bolted on and BOOM- up and running.
  1. Question power steering rack part number?
    By cusford in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-11-2023, 01:37 PM
  2. Steering Rack Part Number
    By brycare in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 25-03-2017, 10:36 AM
  3. Where can i find part number for my steering rack?
    By vicdawg in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-04-2016, 11:43 PM
  4. hi newbie here, having trouble with a3 part number for steering rack
    By bls1711 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 11-06-2013, 11:33 PM
  5. Question Steering Rack Part Number Compatability. 97 1.6 Passat B5. AHL.
    By Bav in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-03-2013, 01:01 PM
