Thread: Heating does not work properly (slow start)
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Heating does not work properly (slow start)
    Dec 2018
    England
    No, not the same garage. The first one said pump leaks and is weak, but i have never had a chance to check with them which pump due to xmas closure. Their diagnosis is free but the charge for pump replacement is too much.
    So i went to the 2nd garage. They said the main pump is all good. Their charge for the auxiliary pump replacement is only £202, compared to £646 quote from the first garage.
  2. Re: Heating does not work properly (slow start)
    Jan 2018
    Sussex
    55 Post(s)
    Quote Originally Posted by smarthomes4u View Post
    Yes aux pump for heater is cheaper and easy to change.
    VCDS fault scan would pick up failure of this part and saved you some time and guessing.
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2013 Golf MK7 1.6 tdi 5 speed
  3. Re: Heating does not work properly (slow start)
    Dec 2018
    England
    Quote Originally Posted by Renars View Post
    I was hoping so. I went to 3 garages totally. two of them did VAG plugin and did not see any related error codes.
  4. Re: Heating does not work properly (slow start)
    Dec 2018
    England
    sadly, the no heating problem has not been solved despite my feeling a bit better just after the axillary pump replacement.
    it still takes ages to get heating (warm air) if parked and idle in the morning. Slightly better if driven on road.
    When parked and idle, heating turned on, blown cold air and I touched the two hoses connecting to the heater core, one is quite hot and the other is much less warm. Apparently not enough coolant flow/heat into the core?
    When heating comes on, if I put fan on a higher power, air become less warm or not warm.
    Still parked, if I rev the engine to 3000 or 4000 rpm, warm air comes out very quickly, even if fan is at full power.
    Now I believe more and more that it's trapped air or clogged heater core. Have booked with another garage for a flush and bleeding of the heater core.
  5. Re: Heating does not work properly (slow start)
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    I feel it would be prudent to properly clean through the microbore of the matrix or potentially be prepared to renew the matrix
  6. Re: Heating does not work properly (slow start)
    Dec 2018
    England
    Got car back from technician. He said that flush was done, however when they tried to purge compressed air through, air came back. Technician said the matrix is blocked. A big bill to take.
    Quote Originally Posted by fourringsrus View Post
  1. Please Help 2010 A3 convertible roof won't work properly, is there a reset procedure?
    By Lockster in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-01-2017, 09:26 PM
  2. Dash fails to work properly
    By Woody87 in forum Alhambra
    Last Post: 05-04-2016, 11:11 PM
  3. Please Help 2007 A4 heating only work on drivers side
    By Spencer1501 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-11-2013, 11:34 PM
  4. Diesel gauge doesn't work properly. What should I do?
    By ntp in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-10-2009, 08:46 AM
  5. Wipers Work Slow
    By j4byx in forum Golf MK4 - 1999 - 2004
    Last Post: 28-01-2009, 01:41 PM
