Thread: Startup problems with Start-stop system and auto parking brake release
  1. Startup problems with Start-stop system and auto parking brake release
    Dec 2018
    Bolton, UK
    Apologies for the long post but it's a fairly specific problem that no-one at Audi seems to be able to help with:
    - Every time I try and start the car from cold the car never starts on the first press of the Start/Stop button (clutch pedal is depressed).
    - All the electrics come on but the engine does not turn over
    - The car will always start on a second press of the start/stop button (clutch pedal depressed) but then an error message appears on the dash' that says "Start-stop system: system fault. Function unavailable". Each time you press the "A OFF" button just below the SD1 slot (i.e. the button to turn the start-stop system on and off) you get the same error.
    - Also the Parking Brake auto release system doesn't work (the "A" button under the parking brake button will not come on no matter how many times you press it and you get another error message on the dash' saying "Parking brake auto release not available".
    - If you turn the car off at this point and then try to start it everything works fine; the car starts first time with no error messages and both the "A OFF" start-stop system, and "A" parking brake auto release works.
    - If you leave the car for 10 minutes and try to start it the same problem reappears - it's almost as if there's something in the startup sequence that is stopping it turning the engine over when it's cold and then causing the two faults.
    What I ususally have to do to make things work is the following:
    - Press start/stop (without the clutch depressed) so all the electrics fire up
    - Press start/stop again (without the clutch depressed), which performs a partial shutdown (some of the electrics stay on)
    - Press start/stop again (this time with the clutch depressed) - car starts and everything works as it should without error messages.
    There are no error codes when you connect it to the VAG diagnostics.
    Anyone any ideas???
    Thanks in advance.
  2. Re: Startup problems with Start-stop system and auto parking brake release
    Jul 2016
    Chestfield kent
    43 Post(s)
    Hi Once it is running, dose the S/S work as normal and the auto parking brake as well. Have you demonstrated it to Audi and they confirm there is an issue, and is it in warranty ? if so I would give it to them saying sort it please .
  3. Re: Startup problems with Start-stop system and auto parking brake release
    Mar 2014
    Edinburgh
    228 Post(s)
    Sound like the switch on the clutch pedal is faulty.
    Auto handbrake relies on detecting the clutch is up or down for it to release.
    Stop start is the same as it needs to knows the clutch position to stop and start.
  4. Re: Startup problems with Start-stop system and auto parking brake release
    18 Post(s)
    460 Post(s)
    Is the battery the original?
  1. PLEASE HELP, EPB Stuck, No Ignition, Cant Release Parking Brake
    By James789 in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 03-12-2018, 07:57 PM
  2. Question: Parking Brake Auto Release/Hill Hold assist doesn't work in 1st Gear
    By Pat Cronin in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 08-07-2015, 08:02 PM
  3. Manual Release of Parking Brake
    By Allmac in forum Golf MK7 - 2013 on
    Last Post: 14-08-2013, 12:28 PM
  4. Question How to Release a Stuck Electronic Parking Brake ?
    By GLROSIE in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-02-2013, 11:52 PM
  5. Parking brake auto release....
    By c4a5er in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-07-2012, 04:29 PM
