Thread: Coolant leak - Culprit is the Coolant inlet valve seal
Page 8 of 12 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 114
  1. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    #71
    Nov 2015
    U.K.
    78 Post(s)
    It is half that price BTW, and I would be interested to see how much an equivalent “all component” extended warranty is to cover the Q7. I’m sure there’s an element of brand premium but at the end of the day using their insurance I expect makes it a hell of a lot easier just getting your broken car fixed at a main dealer when you need it without any hassle, which is worth something.
    Q7 3.0 TDi ABT Power 325bhp MY16 S-Line Tech/Tour/Trailer packs, orca black, 21 inch 9.5J rims, rotor grey leather, sunroof, BOSE, ambient lighting, reversing cam, drivers memory seat. Gtechniq Crystal Serum Ultra ceramic coating. Sent from my iPad using Tapatalk.
    | Q7 3.0 TDi ABT Power 325bhp MY16 S-Line Tech/Tour/Trailer packs, orca black, 21 inch 9.5J rims, rotor grey leather, sunroof, BOSE, ambient lighting, reversing cam, drivers memory seat. Gtechniq Crystal Serum Ultra ceramic coating |
  2. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    #72
    Apr 2013
    donadea co kildare
    See post #59, Maudi25 spent £1100 on warranty, yet they tried to shaft him.
    2007 A6 TFSi Multitronic Auto - Sold.
    2015 A6 3l quattro business edition, cream leather, nav high.
    2018 Lexus LS500H luxury spec.
  3. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    #73
    Oct 2019
    Earth
    23 Post(s)
    I have to change the shut off valve for the 2nd time in 65000km, the car has 67000km, the first time when I’ve changed it, the old part wasn’t upgraded so I got it changed under warranty with the same P/N. This time it seems a new P/N is available since mie-2018, 059121737AR.
    This time even if the car is still under warranty Audi has been a little bit reluctant on supporting the cost, around 800euros, but after some litigation and telling them that I’m gonna sue them, they agreed to support the cost. The car is part of a fleet and has maintenance fleet contract and warranty, don’t know how much this matters though.
  4. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    #74
    Dec 2012
    Birmingham, England
    I have suffered with the coolant leak issue since I bought my approved used Q7 in January.
    Took the car in last week, and thankfully they are fixing it under the 12 month warranty.
    Thought I’d have an argument there.
  5. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    #75
    Apr 2014
    London
    Just had my Q7 3.0 TDi repaired after it started losing too much coolant.
    Brilliant service again from my local Independent VAG service - Pony Road Auto Specialists, Oxford - who confirmed the faulty part was the inlet valve and replaced it.
    Was pleased to hear that it didn’t need any other parts (in other cases the coolant has corroded seals requiring more expensive work) though it was a £500+ job.
    Peace of mind now though.
  6. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    #76
    Apr 2010
    Surrey
    23 Post(s)
    Good result there George, keep an eye on it though, as you will need to top it up at least once as the air escapes.
  7. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    #77
    Apr 2013
    donadea co kildare
    Quote Originally Posted by Georgefdavies View Post
    £500, what was the labour charge? The valve is a common pattern part, £30+ on EBay, maybe £70 at most from a motor factor.
    Coolant Solenoid Valve For Beetle Golf AUDI A3 A4 A5 A6 A7 A8 Q3 Q5 | eBay
  8. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    #78
    Nov 2015
    U.K.
    78 Post(s)
    Quote Originally Posted by folkwagen View Post
    There’s a lot of engine disassembly work involved to get to it apparently. I think mine took most of day at dealer, all in. Rates much higher than independent, but luckily covered by extended warranty.
  9. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    #79
    Mar 2016
    KEnt
    22 Post(s)
    Looks like my q7 might have succumbed to the same issue. Notice a leak on the driveway put some cardboard under the car and looks like it's pink colour.
    Booked into dealer for investigation but next available appt is beginning of June.
    Car has extended warranty, did most people with extended warranty get this fixed, under earranty sounds like there was push back but the dealership helped fight the cause.
    Sent from my SM-G965F using Tapatalk
  10. Re: Coolant leak - Culprit is the Coolant inlet valve seal
    #80
    Jul 2010
    uk
    183 Post(s)
    Quote Originally Posted by Papereyes View Post
    Mine was all fine under warranty (could well
    Have been just inside the three years) my guess is it’ll be covered under the all component extension if you have that. Plus I’d use the it’s a common fault - Andy posted a TSB number earlier in the thread also I think. Good luck with it but nothing until June seems strange as I got my car serviced earlier this week booked in couple weeks back but with appts available from next day.
  1. Coolant leak through EGR valve V6 3.0 quattro TDI
    By Audijager in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-06-2016, 03:21 PM
  2. Question Coolant leak from rear flange: Sourcing the coolant pipe?
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-09-2015, 11:36 AM
  3. Question 1999 A4 2.8 quattro 2.8 - coolant leak under inlet manifold
    By timmyp666 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-02-2015, 05:49 PM
  4. Replies: 8
    Last Post: 19-04-2012, 06:43 PM
  5. Please Help Coolant Leak From Coolant\Water pump Housing
    By Chappio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2009, 03:30 PM
