Thread: A4 2093 3.0 v6 petrol cambelt change - competent DIYer?
Results 1 to 10 of 11
  1. A4 2093 3.0 v6 petrol cambelt change - competent DIYer?
    Liverpool
    11 Post(s)
    As above, an due a cambekt change on our 2003 3.0 v6, was wondering if it’s something a competent DIYer could do, or leave it to the professionals?
    and what are people paying these days at local indy’s To have it changed, along with new water pump with metal internals?
  2. Re: A4 2093 3.0 v6 petrol cambelt change - competent DIYer?
    Nov 2008
    Leeming
    AudiWorld Tech Articles
    when you feel confident and have done yours give me a call you can do mine.
    i have bought all the gear including clamps, pulleys and belts but too scared to do it.
    if there is someone who is competent and wants to earn some cash then give me a shout
  3. Re: A4 2093 3.0 v6 petrol cambelt change - competent DIYer?
    Liverpool
    11 Post(s)
    Hi Blackpool
    Am guessing its a pig of a job if no ones commented. Been quoted £700 at a local VAG specialist, wanted to know if it was reasonable or not. I know someone on here (it may of been Crasher) said not many places have all the correct tools for the V6 engine
  4. Re: A4 2093 3.0 v6 petrol cambelt change - competent DIYer?
    Nov 2008
    Leeming
    If you checked out the link i did above it took somebody roughly 2 days to do it. £700 for the belt and water pump isnt over the top, does that include any tensioners ?
    There are other parts that people choose to get done at the same time, There is the aux belt and tensioner, the coolant temperature sensor is also in that vicinity.
  5. Re: A4 2093 3.0 v6 petrol cambelt change - competent DIYer?
    Liverpool
    11 Post(s)
    Hi Blackpool
    Sorry mate, completely missed your link the first time around, had a look now though and does look like a lot of work. Yeah, the £700 I was quoted locally included (I think) 3 or 4 tensioners or pulleys, new water pump with metal impeller, temp sensor etc. Guess its not too bad a price after all
  6. Re: A4 2093 3.0 v6 petrol cambelt change - competent DIYer?
    1836 Post(s)
    Make sure the people who do it have the proper setting tools, not just a bottle of Tipex and pray....
  7. Re: A4 2093 3.0 v6 petrol cambelt change - competent DIYer?
    Liverpool
    11 Post(s)
    Thanks Crasher, i knew someone had said previously on here about having the correct locking tools for the 30v engine and that not many did, and it must of been you. The more I read, the more inclined I am to go to the local specialist
  8. Re: A4 2093 3.0 v6 petrol cambelt change - competent DIYer?
    1836 Post(s)
    Make sure they have the crank peg and cam cross bar.
  9. Re: A4 2093 3.0 v6 petrol cambelt change - competent DIYer?
    Nov 2008
    Leeming
    This tool should do the trick, a normal garage more than likely wont have it but an independent VAG would
    S-AFSI4 AUDI Timing Tool camshaft locking belt adjustment A4 A6 3.0 V6 ASN BBJ 5902188472233 | eBay
  10. Re: A4 2093 3.0 v6 petrol cambelt change - competent DIYer?
    1836 Post(s)
    I can’t check on my iPad, as it does not have ELSA, which tools you need and my online parts look up system is being silly about my password, which engine code is it? This is the earlier 5v 2.4/2.7T/3.0 V6 cam bar and a MUST on these is being able to get the cam pulleys off of their taper seats without using a hammer as they crack, which is not good...
    h
  1. Misfire after cambelt change on a4 3.0 petrol ASN
    By arvydasxx in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-06-2015, 06:52 PM
  2. A4 1.9tdi 130 Cambelt change Do I need to change hydraulic tensioner
    By warriorsage in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-02-2015, 09:43 AM
  3. Please Help Error code 00262 Solenoid Valve EV3, is this DIYer do-able
    By Wikaniko in forum Touran - Sharan - Caravelle
    Last Post: 11-02-2012, 03:19 PM
  4. 2.0 Petrol - Cambelt?
    By abucksdiver in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-04-2009, 11:29 AM
  5. Opinion on Cambelt change interval for a 1.8T Petrol MK2
    By The Hofmeister in forum Alhambra
    Last Post: 04-10-2007, 12:12 PM
