Thread: liquid to liquid heat exchanger in a passat?
  1. liquid to liquid heat exchanger in a passat?
    Jun 2016
    falmouth
    Hey guys thanks for looking at my thread,
    I'm converting a trailer to be a sleeping area for travelling around and am thinking about heating options. Can you let me know if you think this idea would cause mechanical issues?
    To use a liquid to liquid heat exchanger under the bonnet. The coolant would run through the exchanger and a separate circuit of water would be ran through the other side of the exchanger using a small 12v pump in the trailer. The heated water would run through the under floor heating pipes of the trailer.
    This is the type of heat exchanger I'm thinking of using:
    https://www.ebay.co.uk/itm/Webasto-T...Ryly:rk:7:pf:0
    Cheers!
    Mike
  2. Re: liquid to liquid heat exchanger in a passat?
    Jul 2010
    Monmouth, Wales
    7 Post(s)
    Quote Originally Posted by mikeote View Post
    Webasto Thermo Top C Thermo 90ST Plate Heat Exchanger With Mixer Tap - 4111209A | eBay
    Cheers!
    Mike
    Surely you are not going to leave the engine running all night to keep the trailer warm?
    You would be better off getting a lorry cab heater unit that runs on diesel, and run it on red diesel.
  1. 1.9TDI - Oil to Water heat exchanger
    By Dibs_h in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-09-2012, 02:41 PM
  2. Air Con Heat exchanger
    By phantomdox in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-06-2011, 10:55 PM
  3. Liquid under engine bay
    By TIMCLARK in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-10-2010, 06:37 PM
  4. Dripping liquid under car
    By Mawders in forum Golf MK4 - 1999 - 2004
    Last Post: 14-03-2009, 11:29 PM
  5. liquid blue
    By jcb in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-07-2008, 02:39 PM
