Thread: climate control issue. please help!
  1. climate control issue. please help!
    Nov 2018
    birmingham
    hi,
    so basically ive had a problem with my climate control where the hole motor system has completely shut off. Also i suspect this is the cause of why my car is having a battery drain. I have also replaced one of the motors thinking it was broken but later tested and found out it wasn't actually broken. This has really been driving me crazy as i dont know what to do with the issue. i have a vag com and did some diagnostics and pretty much every time i scan the care it throws up different codes. its basically saying there is a mechanical fault with every single motor in the car....... it does say sometimes it has a short in the system sometimes. i feel that it could be something simple as a wiring issue for it to turn off the hole system. im prepared to take the entire dash out but would feel better about it if i had a guide on how to do it.
    here is one the scans just as an idea of what the problem could be. if anyone could help me i would really appreciate it as im having to jump my car every morning plus drive to work with no heating and steamed windows.
    Address 08: Auto HVAC Labels: 8P0-820-043.LBL
    Control Module Part Number: 8P0 820 043 M HW: 8P0 820 043 M
    Component and/or Version: KlimavollautomatH18 0300
    Software Coding:
    Work Shop Code: WSC 06314 000 00000
    VCID: 3663555C412CE8F4F2-8062
    8 Faults Found:
    01272 - Positioning Motor for Central Flap (V70)
    003 - Mechanical Failure
    Freeze Frame:
    Fault Status: 01100011
    Fault Priority: 3
    Fault Frequency: 219
    Reset counter: 138
    Mileage: 193167 km
    Time Indication: 0
    Date: 2016.07.28
    Time: 21:43:35
    Freeze Frame:
    Voltage: 13.90 V
    Temperature: 23.0∞C
    (no units): 183.0
    (no units): 181.0
    Temperature: 18.0∞C
    01274 - Air Flow Flap Positioning Motor (V71)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 52
    Reset counter: 138
    Mileage: 193167 km
    Time Indication: 0
    Date: 2016.07.28
    Time: 21:43:12
    Freeze Frame:
    Voltage: 13.90 V
    Temperature: 21.5∞C
    (no units): 31.0
    (no units): 220.0
    Temperature: 18.5∞C
    00716 - Air recirculation Flap Positioning Motor (V113)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 104
    Reset counter: 131
    Mileage: 193167 km
    Time Indication: 0
    Date: 2016.07.28
    Time: 21:43:12
    Freeze Frame:
    Voltage: 13.90 V
    Temperature: 21.5∞C
    (no units): 210.0
    (no units): 53.0
    Temperature: 18.5∞C
    01810 - Actuating Motor for Temperature Flap; Right (V159)
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 3
    Fault Frequency: 98
    Reset counter: 178
    Mileage: 193194 km
    Time Indication: 0
    Date: 2016.07.31
    Time: 01:41:03
    Freeze Frame:
    Voltage: 13.90 V
    Temperature: 32.0∞C
    (no units): 32.0
    (no units): 32.0
    Temperature: 19.0∞C
    01809 - Actuating Motor for Temperature Flap; Left (V158)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 137
    Reset counter: 178
    Mileage: 193197 km
    Time Indication: 0
    Date: 2016.08.01
    Time: 02:05:22
    Freeze Frame:
    Voltage: 14.00 V
    Temperature: 22.0∞C
    (no units): 109.0
    (no units): 0.0
    Temperature: 17.5∞C
    00710 - Defroster Flap Positioning Motor (V107)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 73
    Reset counter: 178
    Mileage: 193531 km
    Time Indication: 0
    Date: 2016.08.26
    Time: 09:26:39
    Freeze Frame:
    Voltage: 13.40 V
    Temperature: 25.0∞C
    (no units): 226.0
    (no units): 32.0
    Temperature: 14.0∞C
    01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 140
    Mileage: 194644 km
    Time Indication: 0
    Date: 2016.11.30
    Time: 05:45:09
    Freeze Frame:
    Voltage: 11.90 V
    (no units): 255.0
    Temperature: 19.0∞C
    007 - Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00100111
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 139
    Mileage: 194644 km
    Time Indication: 0
    Date: 2016.11.30
    Time: 10:46:20
    Freeze Frame:
    Voltage: 11.90 V
    (no units): 0.0
    Temperature: 14.0∞C
    Address 08: DTCs cleared
  2. Re: climate control issue. please help!
    Nov 2018
    birmingham
    Anyone ???? Does anyone have a guide on removing the dash????
  3. Re: climate control issue. please help!
    Jul 2009
    Lichfield
    For a guide a Haynes manual is worth the investment. Can be picked up quite cheap now. Word of warning I did this on an a4 to swap a heater matrix. It was a right pain but I got there in the end.
  4. Re: climate control issue. please help!
    108 Post(s)
    1816 Post(s)
    Make sure the battery is fully charged and then carry out the basic settings and see what comes back
  1. weird climate control issue
    By churp in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-11-2011, 10:35 PM
  2. Question climate control blower failure/resistor pack/ control panel ?
    By ianmcneill in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-08-2011, 10:00 PM
  3. Please Help Climate control- intermittent issue
    By reevelee in forum Golf MK5 - 2004 - 2009
    Last Post: 01-08-2010, 08:44 PM
  4. Replies: 2
    Last Post: 08-08-2008, 10:53 PM
  5. Cruise Control / Climate Control
    By Cian_ie in forum Archive posts
    Last Post: 27-01-2008, 08:47 AM
