Thread: 16804 issue
  1. 16804 issue
    Dec 2007
    Hi all
    I've got a 2006 A4 1.8t and can't get rid of the code permanently. I can clear it but engine light pops back up after a few days.
    Code is catalyst system, bank 1efficiency below threshold. Sporadic.
    I ran a test on the vag401 and it said the sensors were ok and the cat was the problem, I changed this and the sensors as I didn't fancy getting involved with it again! I've run cat cleaner through it too, no obvious split pipes either.
    Code still here so any ideas?
    Cheers D
  2. Re: 16804 issue
    20 Post(s)
    489 Post(s)
    You could be barking at the code here
    16804 (P0420)- Catalyst System; Bank 1: Efficiency Below Threshold
    Have you replaced the lambda sensor after the cat or the one before?
  3. Re: 16804 issue
    Dec 2007
    Crasher I have done both. I guess a new one could be at fault though.
  4. Re: 16804 issue
    20 Post(s)
    489 Post(s)
    IF you have replaced the sensors with proper Bosch/genuine items AND there are no other fault codes, the ECU MAY be telling the truth and the cat is sick, but is is highly unusual with genuine cats so it would be a good idea to investigate if it is a genuine cat but it may be hard for you to tell. I could possibly tell if I saw some pictures.
  5. Re: 16804 issue
    Dec 2007
    Hi
    I've run tests today and the sensors are good but the new cat isn't. It was an after market cat so I'll get in touch with the supplier. I didn't want to change it again as it was a pig of a job!
  1. Polo 1.2 - 2005 - Fault Code 16804
    By bigrich1 in forum Polo - Derby - Lupo - Fox
    Last Post: 10-09-2011, 11:22 AM
  2. Question Fault code 16804 - Catalyst System
    By acano in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-02-2011, 08:46 PM
  3. The dreaded 16804 - polo 1.2 awy engine
    By dannyboy123 in forum VCDS - Help Requests
    Last Post: 05-04-2010, 08:55 PM
  4. Please Help 2002 Ibiza 1.2 persistent MIL warning (16804) light!
    By Andrew Pawsey in forum Ibiza - Cordoba
    Last Post: 27-01-2009, 06:10 PM
  5. Code 16804- warning light comes on but no fault?
    By paulco62 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-04-2007, 09:35 PM
