Thread: Abs lights, esp and engine light on
  1. Abs lights, esp and engine light on
    Nov 2018
    Scotland
    Hello
    I’m a new member so I hope this is in the correct place.
    Recently have bought myself another MK5 Golf this being a 1.9tdi (2005). Previously have a 1.6 Fsi which was to be honest a headache with sensor problems.
    I bought this car 2 weeks ago and only travel a short distance to work and havent done much but the car sounds mechanically sound and was a very honest sale however.
    • Abs/ESP light on
    • Brake warning light on
    • Engine light occasionally on
    Previous owner had the abs pump replaced and all abs sensors which i have the old one to prove however wasn’t able to get to the bottom of the problem.
    I have a vagcom lead (cheap off ebay but the software isn’t compatible with windows 7). Will try get error codes but just want to know if anyone has a solution have looked but haven’t seen anything.
    Tempting to stick it into a vw specialist but was hoping there would be a solution i can sort myself as i’m an agricultural engineer.
  2. Re: Abs lights, esp and engine light on
    Oct 2017
    London
    12 Post(s)
    Did you get the error codes? Cheap knock off leads off EBay are a disaster. They may appear to work but they never do properly.
  3. Re: Abs lights, esp and engine light on
    Mar 2019
    I have same issue, had it on a fault reader and it's showing nearside rear wheel speed sensor. So I'd guess your issue could be related to one or more of the same. Looks easy enough fix, and the part is around £40
  4. Re: Abs lights, esp and engine light on
    Oct 2017
    London
    12 Post(s)
    Wheel speed sensor wouldnt put the engine light on though so talking more than 1 fault here.
  1. Replies: 5
    Last Post: 02-12-2013, 06:44 PM
  2. Important led brake lights cause engine managment light problems
    By D_MACD_1979 in forum Touran - Sharan - Caravelle
    Last Post: 04-12-2009, 05:30 PM
  3. engine light /intermittent brake lights
    By stubbsy in forum Golf MK4 - 1999 - 2004
    Last Post: 15-09-2008, 01:12 AM
  4. Please Help EPC Light and Engine Managment lights
    By Peterchaney in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-08-2008, 03:33 PM
