Thread: RNS 310 or 315
  1. RNS 310 or 315
    Aug 2010
    west midlands
    Hello
    Guys I got a 2011 Passat with the RNS 310 or 315. has Bluetooth Sat Nav DAB. I have my phone connected to it Samsung s9. I can make calls etc that's all I use it for. Yesterday for some reason it has lost the Bluetooth connection. I've tried added it again but just get pairing failed message? tried to remove old connection etc nothing working. Where is the Bluetooth module located as I might try unplugging that and connecting again, seen videos which say it's under the passenger seat on the floor but both front seat have nothing underneath they have the electric wires going into the seat for electric lumber support I think?
    thanks
    ice
  2. Re: RNS 310 or 315
    Oct 2009
    Dover
    Hello,
    Don't know if you found the problem or fix but mine did this, had to do the following:
    Turned out to be a phone issue had to go into settings menu on phone then apps
    Top right has 3 dots click this and select Show system apps
    Now scroll down to Bluetooth
    Then go in and select storage then clear cache then data
    Then do a fresh connect with the car
    Hope this helps...
    Sent from my SM-G955F using Tapatalk
