Thread: Parking brake and headlamp warning lights.
  1. Parking brake and headlamp warning lights.
    Sep 2016
    Wexford, Ireland
    OK, so my better half has now had the same problem twice. Both times when it's raining so I'm assuming water ingress somewhere.
    The issue is a warning on the dash for "Headlamps incorrectly adjusted" and "parking brake malfunction" I'm not sure about the headlights but there was actually a parking brake problem, as in it wouldn't work. When she removed the ignition key it did work again.
    As I said, it's happened both times when it's rained. Also, they both come on together.
    I've been out in the car tonight and, as you'd expect, it doesn't do it when I drive it.
    Any ideas anyone?
    2009 2.0tdi e s-line Avant
  2. Re: Parking brake and headlamp warning lights.
    Jan 2013
    Wessex. and Southern France
    108 Post(s)
    One of the myriad of things it could be is water getting into one of the brake units via a cracked casing.
  3. Re: Parking brake and headlamp warning lights.
    Sep 2016
    Wexford, Ireland
    Thanks.
    When you say brake units, what do you mean exactly? Something around the wheels area?
  4. Re: Parking brake and headlamp warning lights.
    Sep 2011
    Kilmarnock, United Kingdom
    12 Post(s)
    Rear caliper motor usually develop the fault
  5. Re: Parking brake and headlamp warning lights.
    Sep 2016
    Wexford, Ireland
    Thanks for that. I'll get that looked at.
    Any ideas why the headlight warning would come on at the same time though??
  1. Please Help ABS, ESP and Parking Brake warning lights on dash.
    By tmurtaza in forum A8 - S8 - V8
    Last Post: 23-08-2016, 06:34 PM
  2. Please Help Polo 56 plate 1.2, headlamp warning won't go stop with lights off
    By Meep in forum Polo - Derby - Lupo - Fox
    Last Post: 01-04-2016, 05:18 PM
  3. ABS, Parking Brake, Squeeking brakes and brake lights!
    By medvwb6 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-10-2011, 05:35 PM
  4. Parking brake warning
    By reynard55 in forum VCDS - Help Requests
    Last Post: 20-12-2010, 04:25 PM
  5. Question Engine warning and parking brake warning lights on at same time
    By ajh in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-05-2010, 05:33 PM
