Thread: 17069 ecu relay
  1. 17069 ecu relay
    Apr 2017
    Kuala Lumpur, Malaysia
    Hi there
    I'm having this problem with my bly 2.0 fsi engine
    Car sometimes doesn't start. Cranks and sometimes run for a second then dies. Dash lights all normal.
    Leave it for a few hours and it starts right up no problem.
    If it happens to start the battery would drain in a few short hours.
    Gave it a scan and got :
    17069/P0685 - ECM Power Relay Control Circuit (J271): intermittent
    Sounded like a sticking relay
    Went ahead and swap the 2 460 relays under the driver side dash. No good.
    Replaced the 2 relays. Same thing as well.
    (I hope this is the correct relay)
    I guess the next is to check the ecm and wiring (which I have minimal knowledge of)
    What would be the next step? Appreciate any help
  2. Re: 17069 ecu relay
    Apr 2017
    Checked all wiring to ecu and everything seems normal. Help anyone?
  3. Re: 17069 ecu relay
    Apr 2017
    Removed and reconnected the battery. Cleared all codes. Now the car starts but it runs like crap for a few seconds then dies. Gave it another scan and this came up
    16577 - Fuel Pressure Sensor (G247)
    P0193 - 001 - Short to Plus
    Quite unlikely to be the sensor itself that's faulty since I replaced it just 2 months back.
    The ecm relay code didn't come back.
    Do these codes point to ecu failure?
  1. Air Con relay
    By AEL in forum Touran - Sharan - Caravelle
    Last Post: 23-04-2009, 06:05 PM
  2. Question relay box
    By staincliffe in forum Bora - 1998 - 2005
    Last Post: 16-02-2009, 03:08 PM
  3. 109 relay
    By r34 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-08-2008, 09:38 PM
  4. Please Help Relay 30
    By sdk778 in forum 80 - 90
    Last Post: 20-06-2008, 10:52 PM
  5. ECU Relay
    By Chel$ea in forum Golf MK3 - 1993 - 1999
    Last Post: 20-01-2008, 05:31 PM
