Thread: Error code P0343 Camshaft Posistion Sensor (G40) Signal Too high.
  1. Error code P0343 Camshaft Posistion Sensor (G40) Signal Too high.
    Jul 2016
    West Lothian
    I have recently had a bit of bother with my old Passat.
    Occasionally losing power in second and third gear just after starting. After a few miles everything seems grand. I recently had the handbrake cables replaced and have subsequently has a bit of bother starting her. Usually starts after three or four turns.
    Engine warning light came on at the weekend .
    Error code Error code P0343 Camshaft Position Sensor (G40) Signal Too high.
    Any idea what this could be / Could it be related to the recent handbrake work the mechanic said it was quite complicated to replace the cables.
    Any advice would be greatly appreciated.
    marky
  2. Re: Error code P0343 Camshaft Posistion Sensor (G40) Signal Too high.
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    It sounds like the sensor is failing or your timing is out, you don't say if petrol or diesel or age, quick check remove the top timing belt cover and check the belt is still tight and look at it while running to see if the belt is flapping about. Unlikely to be related to the handbrake cable job, just the joys of owning an old car.
  3. Re: Error code P0343 Camshaft Posistion Sensor (G40) Signal Too high.
    Jul 2016
    West Lothian
    Cheers for the reply Rob.
    Petrol (does have LPG but not running gas at the minute) shes 2002 137k on the clock and timing belt and water pump changed at 113k
    Im pretty clueless where is this cover and ill have a wee look when I have a chance
  4. Re: Error code P0343 Camshaft Posistion Sensor (G40) Signal Too high.
    Jul 2016
    West Lothian
    Quote Originally Posted by markybhoy75 View Post
    I got the cover off enough to see the belt. Looks pretty new and seems to be running true on the cogs.
    Marky
  5. Re: Error code P0343 Camshaft Posistion Sensor (G40) Signal Too high.
    Nov 2010
    104 Post(s)
    Do you have any other codes since the check engine light came on? Not being funny but if you were struggling to find the cover then I reckon you need to take this to a garage to get the sensor checked and maybe changed or further investigations
  6. Re: Error code P0343 Camshaft Posistion Sensor (G40) Signal Too high.
    Jul 2016
    West Lothian
    Quote Originally Posted by Rob69 View Post
    Hi there.
    Thanks for your reply.
    I do have another error code.
    I will be taking it to a garage but the recent MOT including handbrake left me a bit skint. Really ust want to know that its safe to drive. I only do about 100 miles a week commuting to work
    16558/P0174 - System Too Lean, Bank 2
    Just ordered a fuel filter and MAF do you think i should get a cam sensor as well. Good dicounts on a popular parts site for Black Friday.
    Thanks again
    Marky
  7. Re: Error code P0343 Camshaft Posistion Sensor (G40) Signal Too high.
    Nov 2010
    104 Post(s)
    Don't throw parts at the car, it rarely works and that popular parts site always have deals on and always seem to supply the wrong parts( in my experience of using them!!) Your poor starting, hesitation at acceleration and check engine light are more likely due to the p0174 fault than the cam sensor fault. Is this a V6 engine with lpg? Your fuel / air mix is wrong, too lean = too much air relative to fuel, this could be due to the Oxygen sensor failing, throttle body problem, engine crankcase breathing system, EGR valve problem, split hose on the induction system letting unmetered air into the engine. Could also be your MAF sensor but maybe not. You could remove the engine cover plastic and do some basic checks of plastic pipework and hoses look for splits before garaging it. I think your original cam sensor code is a secondary fault not related to this lean running.
  1. Replies: 0
    Last Post: 09-01-2014, 11:17 AM
  2. Camshaft position sensor ,, no signal
    By elliebumpkins in forum Golf MK5 - 2004 - 2009
    Last Post: 21-12-2011, 07:06 PM
  3. Please Help A4 20v turbo Camshaft Position Sensor error P0343
    By Matty Jones in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-09-2010, 03:03 PM
  4. Replies: 0
    Last Post: 24-01-2010, 12:57 PM
  5. Replies: 8
    Last Post: 07-02-2009, 11:21 PM
