Thread: Auto box lost all oil
  1. Auto box lost all oil
    Jun 2014
    newport, s wales
    Morning All
    Yesterday while driving my A4 B6 Avant 1.9tdi Multitronic. Noticed a loss of drive.
    Got car back home slowly. Gearbox now very noisy.
    Jacked up front offside for a quick look.
    Gearbox fluid every where. It appears to be coming from somewhere above the driveshaft.
    Are there any pipes in this area that could be leaking? Or is the box a sealed Alf contained unit for all fluid?
    I guess Iím looking at an expensive problem?
    Any pointers will be helpful
  2. Re: Auto box lost all oil
    Feb 2016
    Blaydon, North east England
    36 Post(s)
    Could be the oil cooler has ruptured, mine did on my C7 Multitronic.
    I'd try a gearbox service, replace what's split and see what its like after that. Unless you opt straight for a box refurb.
    2015 A6 Allroad 218 - NEW
    2012 A6 Avant SE 3.0TDi Multitronic - OLD
  3. Re: Auto box lost all oil
    Jun 2014
    newport, s wales
    Iím hoping itís a pipe or something straightforward
    Itís going on a ramp today at local workshop. If itís a box required does anyone know the code ?
    1.9tdi 130 Multitronic if itís too expensive it will be broken for spares genuine 112k engine
  4. Re: Auto box lost all oil
    Apr 2013
    gosport uk
    My a4 B6 1.9 tdi auto saloon at 115,00 miles was doing the kangaroo leaps. Fault traced to gearbox. After new D.M.F. and completely re-furbished (rebuilt with all new parts clutches etc.) gearbox the car finally drives like new. I know it would have been cheaper to scrap but i now have a car that should last.
    If I remember correctly the dmf was about £550, and the gearbox was about £2850.
  5. Re: Auto box lost all oil
    Jun 2014
    newport, s wales
    Finally got car onto a garage ramp.
    They found an oil seal had popped out from one of the cooler pipes.
    new seal fiitted and box filled with new fluid.
    Car will now drive and goes through the gears fairly well except it judders when pulling off from rest.
    only seems to occur when gearbox oil is warm. its ok when oil is cold.
    I'm guessing that gearbox is foxxed or words to that effect?
    is this a serious gearbox swap issue?
    I've been quoted £650 for a box from a breaker, so I suggest the fitting costs would take it to about £1000.
    If that is the case I cant justify that spend on a car that is probably worth about £1200ish
    Does anyone know of an economical gearbox for sale?
    cheers
  1. Retro fitting Auto wipers and auto dip interior mirror to my 2001 S6
    By beelzibus in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-08-2015, 08:42 PM
  2. 2003 auto suddenly lost drive and reverse
    By jamie.hayles.5 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-09-2014, 09:03 AM
  3. Auto-Dim Mirror/Auto Lights/Auto Wipers Retrofit
    By mercedeslimos in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-07-2011, 03:50 PM
  4. Replies: 0
    Last Post: 24-12-2009, 09:26 AM
  5. Please Help Ive lost my one and only key fob !
    By Lou Emmerson in forum Beetle 2000-
    Last Post: 01-09-2008, 02:26 PM
