Thread: Mechatronics Failure after ATF change
Results 1 to 8 of 8
  1. Question Mechatronics Failure after ATF change
    Jul 2016
    Preston, UK
    My 2012 Audi A6 C7 underwent the Audi Dealer ATF replacement at the specified 76,000 mile mark. 943 miles later the car failed to start with Gearbox failure warning light. Audi Dealer has diagnosed a failed Mechatronics unit. Is this too much of a coincidence? Second part to my question; Audi Dealer says there will be a delay of at least a week in getting a replacement item as the Mechatronics Unit has to be specifically built for my car! Is this true or just ...?
  2. Re: Mechatronics Failure after ATF change
    1840 Post(s)
    Yes it is an unhappy coincidence, you can’t damage the Mechatronic by changing the oil and yes, each unit is matched to the individual cars VIN so has to be ordered from Germany.
    1 1 0
  3. Re: Mechatronics Failure after ATF change
    Jul 2016
    Preston, UK
    Crasher, thanks for the feedback. Doesn't make £3000 any less painful, but I suppose that's the cost of motoring! Just one final question, are Mechatronics units from 2012 prone to failure at a mileage as low as 76,000? I hope newer units are more reliable. As a septuagenerian this is planned to be my last ever car till I hang up my flying helmet
  4. Re: Mechatronics Failure after ATF change
    1840 Post(s)
    It is not a very common issue on the transverse engine wet clutch DQ250 units, but Mechatronic failure has been something of a problem on the transverse dry clutch DQ200 boxes, so much so it lead to a recal. Yours is a longitudinal installation so will have the DL382 design of the 0CK series and the pre September 2014 versions did have problems with their Mechatronic unit 4G0 927 153 and again in June 2015 to the 4G0 927 153 K at £2654.22 which is what would be fitted now.
  5. Re: Mechatronics Failure after ATF change
    Jan 2013
    Wessex. and Southern France
    109 Post(s)
    Just about to say that!
  6. Re: Mechatronics Failure after ATF change
    Jul 2012
    Staffordshire, UK
    I had the exact same problem at the same mileage point as well - day after being changed, the car broke down in the middle of a busy town roundabout at 6pm with a gearbox failure- it point blank refused to engage any gears! Stoke Audi were superb and replaced mine free of charge even with the car totally out of warranty and lent me a brand spanking new Q5 with 14 miles on the clock for 10 days while they did it!
    Mine is also a 2012 as well.
    1 3 0
  7. Re: Mechatronics Failure after ATF change
    Jan 2013
    109 Post(s)
    That's really good to know, Kudos to them.
  8. Re: Mechatronics Failure after ATF change
    Jul 2016
    Preston, UK
    Thanks Slackworth - this is good grist for the mill. i'll put this to my dealer - Bolton Audi an Audi Customers services, fingers crossed.
  1. Oil pressure failure after oil pump change
    By stu_eg in forum Tiguan
    Last Post: 07-11-2016, 08:41 PM
  2. Lane Change System Failure Warning
    By Audi_Mike in forum A7 - S7
    Last Post: 03-04-2013, 09:31 AM
  3. mechatronics???? causing juddering on pulling away
    By Jacky Turner in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-11-2012, 08:55 AM
  4. Question Another 1.9 Tdi conrod failure. What else to change?
    By macaroni in forum Touran - Sharan - Caravelle
    Last Post: 29-04-2012, 01:55 PM
  5. Question Could ABS head unit failure be related to brake fluid change?
    By wblatchley in forum Touran - Sharan - Caravelle
    Last Post: 23-05-2008, 06:35 AM
