Thread: Stop/Start When Towing
  1. Stop/Start When Towing
    Nov 2018
    Hi, just joined in the hope of getting some information.
    I have a 2014 Passat Estate 2.0 TDI that I tow with. The manual says that the stop/start should be off when towing, but doesn't say why.
    I contacted VW for more explanation, and all they said was it's due to the extra weight and load that the vehicle is pulling. That doesn't make sense to me as the vehicle is stationary when the stop/start is working, so the extra weight and load makes no difference.
    Can anyone explain further?
    Thanks.
  2. Re: Stop/Start When Towing
    May 2012
    Everywhere
    308 Post(s)
    Switch it off permanently !
  3. Re: Stop/Start When Towing
    Feb 2009
    Only a theory, but perhaps to prevent the engine stopping immediately after towing when the turbo is at its highest temperature.
    It would be good to let the engine idle for a time to allow the oil to circulate and dissipate the heat in the turbo, minimising the possibility of the oil in the turbo degrading through heat soakage to the bearings and oilways.
  4. Re: Stop/Start When Towing
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    Its turned off while towing due to the extra load on the electrics and also because a caravan fridge and charging circuit don't play nice with Start/Stop, they go into fault until reset.
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  5. Re: Stop/Start When Towing
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Disable it all the time if you love your engine! I've recently acquired a car with stop start and I now habitually press the 'A' button before driving off, (need to do the change with VCDS). Fuel savings are negligible and stop start is bad for engines, most of an engines wear occurs in the seconds it takes for oil pressure to build up and cutting off the oil flow to a hot turbo is a killer longer term. I think it's an added complexity to a modern car made to make it appear greener and lower emissions tax
  6. Re: Stop/Start When Towing
    Sep 2018
    Witney UK
    19 Post(s)
    Quote Originally Posted by davmal735 View Post
    Yes!
    2017 Audi Q5 Quattro S line Navarro Blue 2.0 litre TFSI, HBA, Powered Mirrors, QVIA AR790 (2 Channel Dash Cameras), Front & Rear parking cameras with smart interface.
  7. Re: Stop/Start When Towing
    Nov 2018
    Sorry for the delay in answering. I forgot about this forum.
    Thanks to KevTrem and davmal735, both of those make sense.
  1. "Start/stop system deactivated you should start your engine manually"
    By AT. in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 31-08-2017, 09:19 PM
  2. Hill start towing a caravan with a passat
    By kalidor in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 15-06-2013, 06:54 PM
  3. How does Start/Stop interplay with Stop-Go on the ACC?
    By Timothy Nathan in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-02-2012, 11:40 AM
  4. start - stop (or rather not)
    By ti rich in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 01-02-2012, 10:28 PM
  5. Stop start on all new 3.0 tdi ?
    By Gary64 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 05-10-2010, 12:30 PM
