Thread: Audi Q7 Cigarette Lighter Fuse Change
  1. Audi Q7 Cigarette Lighter Fuse Change
    Nov 2018
    London
    Hi Guys,
    I have a 2015 Audi Q7 (new shape), registration PN65 KKH.
    Bought second hand and now realised none of the cigarette lighters work. Suspect the fuses have blown so was wondering if someone knew where/how I could access the fuse box & which fuses would need changing?
    Thanks in advance.
    Vinny
  2. Re: Audi Q7 Cigarette Lighter Fuse Change
    Apr 2010
    Surrey
    23 Post(s)
    Just done this recently myself and stuck a larger fuse in because the 20A one always kept blowing.
    Its on the passenger dash side panel iirc. Look in the manual to find which one it is.
  3. Re: Audi Q7 Cigarette Lighter Fuse Change
    Nov 2018
    Portugal
    Quote Originally Posted by inchshort View Post
    What are you connecting to blow a 10a fuse?
    Enviado do meu CLT-L09 através do Tapatalk
  4. Re: Audi Q7 Cigarette Lighter Fuse Change
    Apr 2010
    Surrey
    23 Post(s)
    It’s when a combination of iPad/iPhone chargers are connected, I have the fast chargers plugged in.
  5. Re: Audi Q7 Cigarette Lighter Fuse Change
    Nov 2018
    Portugal
    An iPad/iphone shouldn't draw more than 2a.. Even that we count losses on charger circuit it seems too much
  6. Re: Audi Q7 Cigarette Lighter Fuse Change
    Nov 2015
    U.K.
    78 Post(s)
    You could be looking at 3-5A per device if you are fully exploiting USB3-C and also its power delivery mode...
    Internal Error
    Still I would personally not change up a fuse like that, its got a limit for a reason e.g. other parts/wiring rating.
    Q7 MY16 272PS S-Line Tech/Tour/Trailer packs, orca black, 21 inch 9.5J rims, rotor grey leather, sunroof, BOSE, ambient lighting, reversing cam, drivers memory seat. Gtechniq Crystal Serum Ultra. Sent from my iPad using Tapatalk.
    | Q7 3.0 TDi ABT Power 325bhp MY16 S-Line Tech/Tour/Trailer packs, orca black, 21 inch 9.5J rims, rotor grey leather, sunroof, BOSE, ambient lighting, reversing cam, drivers memory seat. Gtechniq Crystal Serum Ultra ceramic coating |
  7. Re: Audi Q7 Cigarette Lighter Fuse Change
    Sep 2017
    Bristol
    11 Post(s)
    This is interesting because I have blown that fuse a couple of times also. I have an iPad 2 and an iPad 3 inserted in two nextbase iPad holders. Then in the front I have a nextbase dashcam. This all seems to work fine with no issues.
    However I have had two punctures recently (both repairable luckily) And each time I have tried to use the Audi supplied compressor it has blown the fuse. Audi have apparently checked the pump and have said it is fine but I don’t know how well they tested it! The first time I used the pump I only disconnected the dashcam and that blew the fuse. The second time this happened I disconnected everything and it still blew. When I then replaced the fuse and used my wife’s compressor from her A3 etron I didn’t have a problem.
    So I am currently carrying a spare set of 10 amp fuses. Not for the pump but in case the kids iPads go down 🙂
    Next time I am at Audi I am going to insist on them replacing the compressor.
  1. Cigarette Lighter Fuse
    By taxi3528 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-06-2015, 02:32 PM
  2. What fuse for Cab front cigarette lighter?
    By A4B6Cab in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-01-2013, 11:32 AM
  3. Cigarette Lighter fuse 2009 RHD 2.0 tdi sline
    By jcdub in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-04-2012, 08:26 PM
  4. Audi A6 1999 Avant Rear Cigarette lighter fuse??
    By J R Barnett in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-11-2010, 02:08 PM
  5. Question Change a cigarette lighter fuse
    By garydm140vwgolf in forum Golf MK5 - 2004 - 2009
    Last Post: 14-09-2009, 11:37 PM
