Thread: DPF issue even after EGR Valve/Cooler replacement - Return Car or Further Fix? please help!!
Results 11 to 20 of 33
  1. Re: DPF issue even after EGR Valve/Cooler replacement - Return Car or Further Fix? please help!!
    Oct 2018
    London
    Quote Originally Posted by Tripletrouble View Post
    The only was I could see of removing it is driving the car flat out in a low gear to pump massive volumes of air through the DPF and "blow" the ash out?
    When I looked this up before I discovered that ash particles are bigger than soot and also they cannot be burnt off and break down into smaller particles that will pass through the filter. I think that because of this the DPF removal and flush makes sense.
    Sent from my Nexus 6P using Tapatalk
  2. Re: DPF issue even after EGR Valve/Cooler replacement - Return Car or Further Fix? please help!!
    Mar 2018
    GB
    19 Post(s)
    Powerenhancer | Largest Independent Stockist of Fuel & Oil Treatments, AR6400-D 430 gives everything a clear through. Use EA189 as a discount code for 20% off. They do a service kit with an oil treatment as well.
    Sent from my SM-G950F using Tapatalk
  3. Re: DPF issue even after EGR Valve/Cooler replacement - Return Car or Further Fix? please help!!
    Oct 2018
    London
    Quote Originally Posted by bill.wj.wilson View Post
    Thanks for the code. Theres nothing but glowing reviews regarding this product on the website and I will be ordering mine tomorrow.
  4. Re: DPF issue even after EGR Valve/Cooler replacement - Return Car or Further Fix? please help!!
    Oct 2018
    London
    So an update... car went into limp mode again with coil flashing and engine light on. I am told now by the dealer that i purchased car from that it needs to go to Audi to have a software update as when the "specialist" replaced the EGR and cooler this software update was not applied.
    Anyone heard anything about a software update needed when replacing an EGR vale and cooler?
  5. Re: DPF issue even after EGR Valve/Cooler replacement - Return Car or Further Fix? please help!!
    1837 Post(s)
    There are updates for updates on certain models, it has to go on ODIS Software Version Management to see if anything is required. Be warned the if the DPF is blocked the Audi dealer will not entertain the idea of cleaning, only replacement with a genuine unit at £1200.
  6. Re: DPF issue even after EGR Valve/Cooler replacement - Return Car or Further Fix? please help!!
    Jun 2015
    Europe
    Been here a long time ago. DPF had to be replaced by Audi to fix. Alternative is to remove and do DPF delete.
    R8 V10 plus 2016. Stock no mods so far.
    A6 Avant Black Edition 2014 BITDI STG 3 @ 459 Bhp 912NM.
  7. Re: DPF issue even after EGR Valve/Cooler replacement - Return Car or Further Fix? please help!!
    #17
    Jul 2017
    Maidstone, Kent
    49 Post(s)
    Quote Originally Posted by Jackblack View Post
    If you are in the UK, then just be aware that if you go the DPF delete route it will be an instant MOT failure.
    Audi A6 Avant 2019 Black Edition, C8, 3.0TFSI S Tronic. Tech Pack, Parking Pack, Tow Bar, Tour pack.
  8. Re: DPF issue even after EGR Valve/Cooler replacement - Return Car or Further Fix? please help!!
    #18
    May 2012
    Everywhere
    308 Post(s)
    They can't see the weld on blind side and if the mapping is right not smokey , I've a remapped Euro 3 so no dpf that records 0.34 !
  9. Re: DPF issue even after EGR Valve/Cooler replacement - Return Car or Further Fix? please help!!
    #19
    Jul 2017
    Maidstone, Kent
    49 Post(s)
    Quote Originally Posted by Gazwould View Post
    They can't see the weld on blind side and if the mapping is right not smokey , I've a remapped Euro 3 no dpf that records 0.34 !
    But won't it still be very easily identifiable as the MOT test compares the emissions vs the manufacturers VIN details. With no DPF you will be miles out surely?
  10. Re: DPF issue even after EGR Valve/Cooler replacement - Return Car or Further Fix? please help!!
    #20
    May 2012
    Everywhere
    308 Post(s)
    My father has a Euro 5 dpf removed , egr off Stage 1 file and it passed .
    First blow was around 1.00 then settled to a low average figure
    PASS !
  1. After EGR valve, EGR cooler and fuel replacement engine has vivration!
    By Sambor11 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 20-06-2018, 07:43 AM
  2. Heat Dissipator (return fuel cooler) audi a5 3.0tdi
    By ferguslyon1221 in forum 3.0TDi - Engine
    Last Post: 03-11-2017, 07:59 PM
  3. Question replacement of EGR valve/Cooler needed
    By Keian in forum Parts & Accessory Price Requests
    Last Post: 31-08-2016, 11:45 AM
  4. oil cooler replacement
    By white.akita in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-01-2011, 06:20 PM
  5. non return valve in vacuum line?
    By barney2 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-12-2007, 05:30 PM
