Thread: New gearbox - now have issues with gears and cruise
Results 1 to 10 of 16
  1. New gearbox - now have issues with gears and cruise
    Dec 2008
    All, I’m after some advice please. I have just had to have a 2nd hand gear box added to my a6 avant 2010 c6. Everything went well but now have the following issue-
    The gear change selector on the LED display work as it should do for 1st - 3rd gear but as soon as I go to 4th it goes blank 4th and 5th gear is also the same but when in 6th gear it says I’m in 5th and need to change to 6th.
    The second issue I have is cruise control works up to 3rd gear but then drops when go to 4th gear and can’t re enabke it whilst in 4th - 5h gear but works again when in 6th and car telling me to change to 6th from 5th.
    There aren’t any loose wires, I’ve reset the systems by disconnecting battery for 10 minutes but still have this issue.
    Has anybody every had this when changed a gearbox and if so how did you fix the issue?
    Many thanks for you help in advance.
  2. Re: New gearbox - now have issues with gears and cruise
    Sep 2011
    Kilmarnock, United Kingdom
    12 Post(s)
    Did you done VCDS gearbox adoption?
  3. Re: New gearbox - now have issues with gears and cruise
    1836 Post(s)
    Did you fit the same code gearbox?
  4. Re: New gearbox - now have issues with gears and cruise
    Dec 2008
    No we haven’t done this as... as we only changed the gearbox and no sensors we didn’t think that this needs to be done
  5. Re: New gearbox - now have issues with gears and cruise
    Dec 2008
    Yes I believe the same code gearbox was fitted as the old one had to be dropped to access the code for the replacement box.
  6. Re: New gearbox - now have issues with gears and cruise
    1836 Post(s)
    The full basic settings first to match the box to the new installation. Ideally you should have noted the coding value of the old one to make sure the new one is the same and if not, re code it IF it is a suitable box. If basic settings and a coding check to not help then you will need to investigate which box has been fitted and what the original was and make sure the new one is compatible.
  7. Re: New gearbox - now have issues with gears and cruise
    Dec 2008
    Many thanks crasher I shall have a look later at VCDS and also see what the garage says again.
  8. Re: New gearbox - now have issues with gears and cruise
    Dec 2008
    The garage have checked all the gearbox codes and they all match up.
    Nobody can seem to help with what the exact issue is.
  9. Re: New gearbox - now have issues with gears and cruise
    1836 Post(s)
    Can you message me your cars reg number and try and find out the details of the donor car?
  10. Re: New gearbox - now have issues with gears and cruise
    Dec 2008
    Many thanks, I have now messaged you the reg 👍
  1. My gearbox has lost 1 and 2 gears :(
    By mumutley in forum TT - 8N Forum - 1998 - 2006
    Last Post: 13-02-2016, 08:38 PM
  2. Changing up the gears on the Tiptronic gearbox
    By EvilPostIt in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 19-07-2013, 09:13 AM
  3. Gearbox slipping in 2nd and 3rd gears
    By SLEACH in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 25-06-2013, 10:36 PM
  4. Help, gearbox stuck in two gears which engine codes please?
    By Dj0gt0 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-12-2012, 12:47 AM
  5. Cruise Control Query - Manual Gears
    By simfin in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-01-2011, 10:43 PM
