Thread: Fault identification - is it safe to drive?
  1. Fault identification - is it safe to drive?
    Mar 2016
    Banbury, UK
    With everything seemingly electronic these days, a multitude of problems may be hidden under a common fault light - such as the amber engine warning indicator.
    Rather than having to (try) and call upon the services of rescue/recovery agencies to diagnose the fault, is it worthwhile investing in a magic box of my own? (an A6 and a Skoda in the household btw).
    I'm a bit puzzled by the differences and capabilities of the VCDS HEX-V2 system compared to an OBDii tester (e.g. NEXPEAK.... (other devices are available)). Clearly one is far more expensive than the other, but for a non-mechanic is one more appropriate than the other?
    More specifically, the current fault is P0674 - glow plug 4 open circuit. Car seems to run OK, as usual, mpg is normal, no smoke or noise. Audi dealer can't see me for another 12 days!!! (A6 65 plate 2.0 TDi ultra auto)
    Would appreciate the thoughts of this excellent and well-informed community. Many thanks.
  2. Re: Fault identification - is it safe to drive?
    Jan 2018
    Sussex
    26 Post(s)
    Only VCDS will give you decent information on VAG cars.
    VCDS would probably be more specific on whats wrong with glow plug circuit.
    Codes with P in front are generic not VAG specific.
    You can start with glow plug check.
    Generic code readers might give no info at all on some faults.
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2011 Golf MK6 1.6 tdi CAYC 5 speed
  3. Re: Fault identification - is it safe to drive?
    Mar 2018
    GB
    12 Post(s)
    A glow plug has gone, used to be they were only for starting but now help continue the burn, probably worth replacing a set if you're doing one.
  4. Re: Fault identification - is it safe to drive?
    Nov 2010
    Shetland & S.Tyneside
    96 Post(s)
    It used to be the case glow plugs would last 10's of thousands of miles but thanks to the marvels of modern diesel technology we now have pressure sensing glow plugs falling over after a few years.
    https://www.borgwarner.com/newsroom/...sor-glow-plugs
  1. Snapped spring - still safe to drive?
    By toff in forum Touran - Sharan - Caravelle
    Last Post: 02-02-2015, 01:08 AM
  2. drive safe this christmas
    By zollaf in forum Chat - Adult Banter - Sponsored by Audi VW Specialist Centre
    Last Post: 31-01-2013, 01:44 AM
  3. Please Help Brake Fault STOP ABS, safe to drive ?
    By roguetone in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-03-2011, 03:44 PM
  4. VW Passat Fault - is it safe to drive?
    By stevepil in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-10-2010, 06:22 PM
  5. Question Is it safe to drive ?
    By eric black in forum Bora - 1998 - 2005
    Last Post: 11-05-2010, 10:06 AM
