Thread: Audi A3 Poor Staring & Misfire (any help appreciated)
  1. Audi A3 Poor Staring & Misfire (any help appreciated)
    Mar 2018
    Darlington
    Hi Guys,
    I have a 2009 Audi A3 1.9TDI, Engine code BLS.
    My car struggles to start, and when it does it misfires and smokes from the exhaust. I had a diagnostic tool plugged into it and it gave me the following fault:
    P0407 - Exhaust recirc. position sensor, signal too low.
    I have replaced the EGR itself an it has made no difference.
    My next thing to check would be wiring to the EGR and the EGR pressure solenoid valve.
    Any help would be greatly appreciated.
    Thanks.
    Rob
  2. Re: Audi A3 Poor Staring & Misfire (any help appreciated)
    1840 Post(s)
    So you have replaced the EGR valve unit 03G 131 502 B and cleaned the housing?
  3. Re: Audi A3 Poor Staring & Misfire (any help appreciated)
    Mar 2018
    Darlington
    Yeah, that’s right I replaced the full unit.
  4. Re: Audi A3 Poor Staring & Misfire (any help appreciated)
    1840 Post(s)
    Which make of unit did you fit and do you have the part number off of the box?
  5. Re: Audi A3 Poor Staring & Misfire (any help appreciated)
    Mar 2018
    Darlington
    It was a Pierburg, brand new and the part number was the same as the one I took off - 03G 131 502.
  6. Re: Audi A3 Poor Staring & Misfire (any help appreciated)
    1840 Post(s)
    So you are still getting code P0407? I would have expected P0403 instaed.
  7. Re: Audi A3 Poor Staring & Misfire (any help appreciated)
    Mar 2018
    Darlington
    Yeah, still P0407...that's the only code in there.
    Cheers.
  8. Re: Audi A3 Poor Staring & Misfire (any help appreciated)
    1840 Post(s)
    I looked at the wiring diagram and the known issues folder and there are known problems with the EGR valve but that should give code P0407. The EGR valve is driven directly from the ECU with no separate fused power feed (not a great idea) so you need to use a multimeter and the diagram (I can email this if you need it) to measure the continuity of the wiring from the ECU plug to the EGR valve plug, there are no connectors in the wiring where faults can occur which vastly reduces the potential for a wiring fault but you have to check it. If the wiring is good and the code your reader is showing correct (what are you using) the it comes down to a faulty new valve or faulty ECU which is unlikely but does happen and the design of the valve wiring could lead to a faulty valve damaging the ECU. The ECU plugs are a right sketch to get at.
  9. Re: Audi A3 Poor Staring & Misfire (any help appreciated)
    Mar 2018
    Darlington
    Hi thanks for your help, emailing me the diagram would be greatly
    appreciated...I believe the guy who plugged it in used a snap-on code reader.
    roberttaylor1997@hotmail.com
    i will have a look on Sunday and let you know how I get on.
    Thanks a lot.
    Rob
  1. Replies: 4
    Last Post: 11-12-2012, 10:00 PM
  2. 2006 2.0tdi transporter poor staring????
    By az1982 in forum The Commercial Range
    Last Post: 17-02-2010, 11:20 PM
  3. Please Help 2.0 GTi poor running and misfire
    By Arge in forum Golf MK4 - 1999 - 2004
    Last Post: 24-09-2009, 12:09 PM
  4. Audi A6 1999 staring problem - very strange!
    By djrussf1@yahoo. in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-04-2008, 08:13 PM
  5. Light misfire and poor fuel consumption on 2.8 ACK engine
    By ajsphead in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-02-2008, 08:59 PM
