Thread: 1.8T Avant died on motorway, no brakes, cant start (does crank).... Help
  1. 1.8T Avant died on motorway, no brakes, cant start (does crank).... Help
    Jul 2013
    Sweden
    Hi all,
    So for 6 years ish I have been looking after my A4 B6 1.8T Avant. I feel like I have changed a fait bit from most of the sensors, timing belt, etc... Last week I was driving home and on the motorway the car refused to accelerate, then started slowing down (brakes were no longer pressurised) and I needed to pull off. Car turned over but would not start up.
    After a tow home and a few days trying to get to the bottom of what the cause is, I have the following:
    No fault codes - I have tried removing the battery for a few minutes - still nothing (but the ECU is talking to my canbus computer)
    First thought was fuel pump - it is pumping no problems - plenty of pressure
    Starter motor is turning the motor/timing belt
    Spark - all four spark plugs checked, sparking as the engine turns
    When I now crank the engine, the sound is much higher pitch than normal
    I thought possibly the cam sensor (hall effect) but that seems to be providing a signal as the engine cranks
    I wondered if maybe the timing chain inside the engine could have snapped and is not opening/closing the valves correctly. Or if the engine speed sensor has died - could that cause the engine not to fire up?
    Any other thoughts?
  2. Re: 1.8T Avant died on motorway, no brakes, cant start (does crank).... Help
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Engine speed/crank sensor died recently on my 1.8t ( fitted in 225 TT,but essentially the same motor)
    The car just died as if it was switched off, it would crank over happily but not fire up.
    A friend came to tow me out of traffic, whilst on the tow rope I bump started the car in hopefulness and she ran fine.
    Following evening the car did exactly the same thing at the very same road junction.
    This time I bump started on the tow rope straight off rather than being towed around town without power steering or brakes.
    The next couple of days she started on the key perfectly but I was not prepared to accept that things were fine.
    After a bit of research on this fine forum ,it was clear that the issue was typical of the crank sensor failure, so I replaced that with new genuine as recommended by our friend "crasher" on the forum and she has been fine since.
    There were other issues, such as rev counter messing about, but when I described the issue to "crasher" he was 100% that my issue was the crank sensor playing typical failure games.
    I hope this is of some help, good luck
    Stuart
  3. Re: 1.8T Avant died on motorway, no brakes, cant start (does crank).... Help
    Jul 2013
    Sweden
    Ok replaced both the hall sensor and engine speed sensor. No change. I opened up the top of the motor, everything turns over on cranking. Can't see any damage. The chain is son, taught, etc...
    The starter is still very high pitch compared to how it sounded before the incident. If the timing belt had skipped a tooth, what could I look for?
    Anyone have any other thoughts?
  4. Re: 1.8T Avant died on motorway, no brakes, cant start (does crank).... Help
    Jan 2009
    Birmingham
    35 Post(s)
    Found this online if any help
    do you get codes now? also, if its taking 30-40 seconds of intermittent cranking, it could be the the cam is off timing. i had this issue, it was off 1 tooth and would take a bit of cranking. but i got codes for intake cam advance setpoint not reached(cam over retarded)
    if you want to check, take spark plugs out, set engine to cyl 1 TDC, remove valve cover and look at the chain side, on the exhaust and intake cam bridge, theres an arrow ^. count the number of chain links between the two marks. there should be 16.
  5. Re: 1.8T Avant died on motorway, no brakes, cant start (does crank).... Help
    1837 Post(s)
    The change in pitch suggests a compression problem, you need to check your cam belt timing first.
  1. Replies: 3
    Last Post: 15-08-2016, 09:21 AM
  2. Replies: 3
  3. Question Have a A6, 2006, V6 3.0, QUATTRO AVANT, crank but no start
    By leesks in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-07-2015, 10:07 PM
  4. A6 Avant 2.7tdi 2008 manual 66k miles - engine died and will not start
    By gringosmith in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 31-05-2015, 08:24 PM
  5. Tdi died and wont start,battery light came on before it died..
    By imortalmonkey in forum Golf MK4 - 1999 - 2004
    Last Post: 26-10-2010, 05:44 PM
