Hi all,
My Audi Q7 2008 has air suspension fault, car has had a new pump & relay fitted just before getting the car.
We had a quick look the other day & both front height sensors were pulling out of top arm, fitted two new sensor & calibrated.
We have a fault code of 02645
Adaptive suspension valves mechanical fault ?
This was the original code in car.
Fault with only clear when ign on,eng off.
Start the car & fault is there all the time + yellow light on dash flashing.
Pump dose not fire up, but will in output tests
could had have a fault with valve block?
