Hi all,
Issue with my rear passenger window. The motor works ok, but if i put the window all the way down and then go to put it back up, the window gets so far then comes back down like the anti trap is kicking in. Upon further inspection, ive noticed the window will go so far up straight in the door seal runners, but then it will tilt slightly, which causes it to struggle and then the anti trap kicks in. If i push the window to straighten it, it will go up fine again (though it may tilt again and I repeat the same process).
Could this just be a clip thats broken causing the window to move laterally?
