Thread: Brake Light Failure on one side - Bulb and Fuse are OK
  1. Brake Light Failure on one side - Bulb and Fuse are OK
    Jan 2009
    Hi all
    Audi A4 B6 Avant 2003
    Getting a series of warning messages, when switching on ignition, bit concerned as MOT is looming..
    Rear Left Brake
    Rear Parking Light
    Rear Left Fog
    In actuality, only the brake light isn't working on that side (works on RHS)
    The Parking light and Fog light are ok
    I changed the bulb for a new one - same problem.
    Checked the brake light fuse - ok (there is one 10A fuse for both brake lights)
    Not sure what else to check, I've had the cluster out to change the bulb and the connections all look ok, no corrosion etc.
    Can anyone suggest how to progress with fault finding?
  2. Re: Brake Light Failure on one side - Bulb and Fuse are OK
    1837 Post(s)
    Always the left! Check the Earth pin in the plug and bulb holder, it is probably burnt out which means new plug, repair wire and bulb holder.
  3. Re: Brake Light Failure on one side - Bulb and Fuse are OK
    May 2016
    Portsmouth
    I’m having a similar issue but on the right side , rear right light warning , it’s intermittent but mostly on as a warning ⚠️
    I bought a known working used cluster and swopped them around and actually made it worse and got faults popping up for the left side fog 😂
    So put the old one back in , cleaned it all up, checked it over and checked the plug pins and bulb seats too, all looks well but the right side stop light still isn’t working and have the intermittent warning ⚠️ for it
    If I play about with the plug 🔌 I can get the fault to sometimes disappear leading me to believe it’s just a bad contact in the plug 🔌 but how do I open it up to check? Looks sealed
    Anything I can check too? As a new cluster ain’t cheap and might not even be the problem
  1. Please Help Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    By IrlA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2012, 12:56 AM
  2. Brake Bulb failure or not ?
    By Rusyp in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-03-2011, 10:30 AM
  3. Replies: 6
    Last Post: 16-11-2010, 04:44 PM
  4. Please Help Brake Lights not working: Not Bulb or Fuse.
    By Funkedvag in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 24-02-2010, 02:14 PM
  5. bulb blown in high level brake light. MOT failure?
    By dansansome in forum Chat - Anything with wheels
    Last Post: 02-07-2008, 12:29 PM
