Thread: ABS coding help
  1. ABS coding help
    Oct 2018
    County Down, Northern Ireland
    Is there anyone that could help me I lost my abs coding when instrument cluster broke and it seem to have wiped out the abs coding and just left all 00000000s now I don’t have a code for it I did have a guy out looking at it and he said the abs needed replaced but it was working fine until the clocks broke so I no the abs pump is ok just need coding could anyone help
  2. Re: ABS coding help
    1841 Post(s)
    Which system is it, the Mk60 or Mk61? The Mk61 can be a total nightmare and VCDS can’t do it, VCP can SOMETIMES but often we have to use the dealer system ODIS. A year or so ago I had a 2009 A3 (same ABS pump) in with a faulty dash and my ODIS was not working so I was going to take it to a friends who’s system was working. I started it up to go there and the ABS light came on and I thought, “sod it, I will deal with that when I get back” and went off to fit and code the dash. When I got back, VCDS showed a blank coding value and would not let me recode, I did not have VCP then. I had a mobile coding specialist come out and he fought it for hours and in the end managed to get the coding value back in with help from Audi in Germany through contacts he had. As a side point, can you imagine trying to explain this to my customer, it came in with a dash fault and whilst I had it the car went faulty with an unrelated problem but you try explaining that!
  3. Re: ABS coding help
    Oct 2018
    It’s the MK60EC1 I have vcds but it’s a copy one so I cant go to Ross-tech for help so I think I’m gona have to eventually go to a dealer absolute nightmare
  1. abs coding
    By olemangor in forum The Commercial Range
    Last Post: 20-10-2016, 08:11 PM
  2. RNS-E Coding???
    By Pollytron in forum VCDS - Help Requests
    Last Post: 21-10-2012, 05:42 PM
  3. Coding help
    By phil miller in forum VCDS - Help Requests
    Last Post: 24-03-2011, 12:01 AM
  4. Key fob coding
    By audia4tdv in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-01-2010, 05:23 PM
  5. Question ECU coding
    By yuley in forum Golf MK4 - 1999 - 2004
    Last Post: 03-03-2009, 08:19 PM
