Thread: Fuel Filler Flap Replacement
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: Fuel Filler Flap Replacement
    Apr 2016
    Sheffield, England
    Thanks for all the comments. I have sent an e-mail to Audi and appealed to them for a repair as a goodwill gesture, as the car is six months out of warranty. I'll wait and see what they say.....
  2. Re: Fuel Filler Flap Replacement
    Apr 2016
    Sheffield, England
    No surprise there then........... Audi said 'No'
    I must admit I'm disappointed, particularly as the problem first started whilst it was under warranty. Not the kind of service I expected from Audi.
  3. Re: Fuel Filler Flap Replacement
    Apr 2016
    Sheffield, England
    Has anybody carried out this repair themselves?
  4. Re: Fuel Filler Flap Replacement
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    Quote Originally Posted by Hellfire View Post
    Me on my last C7, cost £25 from dealers for the solenoid and took about 20 mins to do. Was a couple of years ago now though.
    Managed to lever the black plastic surround out from behind the filler flap, that gives you access. From there you should be able to make out what your doing. Coloured cover for the flap removes easily.
    The way to do it by the book is to stick flat blade screwdrivers through the raised bit and pry it out, the replace the black surround along with flap hinge etc. Trim tools or a bit of cloth behind a small flat screwdriver meant I didn't need to replace that bit.
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  5. Re: Fuel Filler Flap Replacement
    Apr 2016
    Sheffield, England
    Thanks for that. How did you lever the black plastic surround out? Are there any fixings that need to be removed first? I presume you did this first before removing the outer coloured cover?
  6. Re: Fuel Filler Flap Replacement
    Feb 2016
    53 Post(s)
    I used a flat blade screwdriver to get between the paint and the black plastic, then carefully levered it away so I could get a bigger screwdriver in. Its clipped in so just pulled out.
  7. Re: Fuel Filler Flap Replacement
    #17
    May 2008
    Yorkshire
    Common problem. Audi replaced mine under warranty without question. Car registered Jan 16 - Replaced in June 2017. Don't take no for an answer. Speak to Audi UK if they are giving you the run around.
    2020 B9 A4 Avant Black Edition S Tronic
    2016 FL C7 A6 Avant Ultra Black Edition S Tronic | 2015 FL C7 A6 Avant Ultra Black Edition - S Tronic
    2012 B7 A4 Avant SLine |2008 B7 A4 Avant Sline | 2008 VW Golf PD150 GTI | 2007 VW Golf PD150 GTI
    2004 B6 A4 Avant Sport | 2000 A3 1.8T Sport | 1983 VW Golf GTX
  8. Re: Fuel Filler Flap Replacement
    #18
    Apr 2016
    Sheffield, England
    I already have....... Audi UK said 'No'
  1. Fuel filler flap
    By Lost slip in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-03-2016, 03:24 PM
  2. Fuel filler flap sticking
    By Pikey Narna in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 27-05-2015, 08:04 PM
  3. Fuel Filler Flap not opening.
    By Q7quattro in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 14-05-2015, 02:35 PM
  4. fuel filler flap
    By yogise in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-08-2009, 09:31 PM
  5. Fuel filler flap - '02 Passat TDI
    By mccallu in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-02-2009, 01:22 PM
