Thread: Passat B7 Engine Vibration.
  1. Passat B7 Engine Vibration.
    Oct 2018
    Whitehaven Cumbria
    Hello, I have a 2014 Passat 2.0 TDI Bluemotion Estate which has covered 32000 miles.
    About 1000 miles ago the engine started to vibrate.
    The vibration is only felt at 1300 rpm and seems to disappear 50rpm above or below this figure.
    The vibration occurs when the car is stationary and out of gear and in gear, accelerating and decelerating.
    There is no noise associated with this vibration an the car’s performance seems unaffected.
    The vibration is not massively intrusive but it shouldn’t be there, any advice you guys can give would be gratefully received.
    Thanks, Dave C.
  2. Re: Passat B7 Engine Vibration.
    Jan 2018
    Sussex
    55 Post(s)
    Quote Originally Posted by Dave 01 View Post
    Thanks, Dave C.
    As it happens only at set RPM its some engine balancing issue, but at that mileage don't have exact suspicion on something.
    Better wait if it goes worse if it will, or now will spend money unnecessarily.
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2013 Golf MK7 1.6 tdi 5 speed
  3. Re: Passat B7 Engine Vibration.
    Oct 2017
    Halifax, West Yorkshire
    22 Post(s)
    Has it had all filters changed? Dirty fuel filter caused engine to judder at a set rpm in any gears.
  1. Vw passat 1998 se tdi engine vibration
    By alang498 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-10-2012, 10:44 AM
  2. Engine/Transmission - Vibration/Noise at certain engine revs
    By audikid in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-08-2012, 09:32 AM
  3. passat tdi 130 2002 engine vibration
    By wok2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-09-2007, 09:29 PM
  4. Passat Tdi engine(?) vibration.
    By alba_tdi in forum Archive posts
    Last Post: 29-08-2007, 12:00 PM
  5. Passat 06 TDI - vibration under bonnet after engine turned off
    By stoo in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-08-2007, 07:40 PM
