Thread: Audi A7 - Advice About Engine Change
Results 1 to 10 of 17
  1. Audi A7 - Advice About Engine Change
    Sep 2018
    Uk
    7 Post(s)
    Sorry if posted it in the wrong place
    been offered a audi a7,
    To cut it short milage is 115,000 Replacement engine was fitted which has 89,000 so clock now has 89,000
    Also m.o.t was done this year with the 100+ miles and then i presume after engine was fitted m.o.t has been done again
    I have queried this and the garage said the dash and engine came out of the same car? or it would not of started as its coded together? he doesnt have the information for the where it came from as he brought it like that and cannot get it,
    is the garage correct about needing both the clock and engine for it to work?
  2. Re: Audi A7 - Advice About Engine Change
    Jan 2018
    Sussex
    55 Post(s)
    Mileage is saved in many modules in this car.
    ECU is responsible for what is shown on dash, so why would dash need changing and just a dash change would make no difference in what is shows.
    Something weird about that car be careful.
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2013 Golf MK7 1.6 tdi 5 speed
  3. Re: Audi A7 - Advice About Engine Change
    Sep 2018
    Uk
    7 Post(s)
    ok thank you
    so speedo dash nothing to do with engine if engine changed,
    Trying to get a receipt of the engine change but nothing - i guess he has clocked it back and using a replacement engine as an excuse?
  4. Re: Audi A7 - Advice About Engine Change
    Aug 2007
    Hook Hampshire
    21 Post(s)
    If the salesman knows nothing about the car. Stay well clear! This is like buying a car with problems but no history and if you have chosen wrongly, it will cost you a fortune. These V6 engines are good for 300,000+ miles, so what went wrong.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  5. Re: Audi A7 - Advice About Engine Change
    Jan 2018
    Sussex
    55 Post(s)
    Quote Originally Posted by shabazmo View Post
    Most of it is good for 300k, not the two chains and tensioners, which is gearbox off job.
    Current cars:
  6. Re: Audi A7 - Advice About Engine Change
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Quote Originally Posted by Renars View Post
    Thanks Renars, what the life expectancy of the chain and tensioners, and does your comment apply for both long life 20k mile servicing and standard 10k servicing.
  7. Re: Audi A7 - Advice About Engine Change
    Jan 2018
    Sussex
    55 Post(s)
    Longlife will make it die faster, but around 200 000 they usually are in pretty bad state and rattle a lot on startup.
    Hard to say when its critical, but not a good idea to test it.
    When chains are quite stretched there is significant rattle at startup for 2-3 seconds. If it rattles longer it is critical.
    If you don't drive very much like 50k a year, there is no real reason to do a longlife oil changes.
    Current cars:
  8. Re: Audi A7 - Advice About Engine Change
    Sep 2018
    Uk
    7 Post(s)
    I did think they last a very long time may be he's using a engine change to try and justify the clock being clocked back. Apparently 1 owner from new on log book full service history until now. Thanks I will just leave it alone. Wh3n you find the perfect car obviously there would be an issue lol
  9. Re: Audi A7 - Advice About Engine Change
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Just a thought. If it has full service history, an audi dealership should be able to log in and tell you the history of the car. irrespective though, I would much rather pay a couple of grand more for a car which has been cherished since new.
  10. Re: Audi A7 - Advice About Engine Change
    Jan 2018
    Sussex
    55 Post(s)
    Quote Originally Posted by Djbubbbbbz View Post
    Everything is in price. Sketchy cars have to be cheap as you may have to fix something.
    There is always some engines that may fail quickly even if generally same type lasts long.
    Relatively fresh car with engine change have to be under market price (If not done by dealer under warranty with all papers and history), only when its older it would even out.
    Current cars:
  1. audi a4 b7 2.0 tdi blb engine change to 1.9 tdi awx engine ??
    By rolmeister1965 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-09-2018, 08:45 PM
  2. audi a4 2.5 tdi quattro engine oil change
    By nath2000 in forum Chat - Anything with wheels
    Last Post: 22-07-2017, 02:18 PM
  3. Polo 1.4 16v BBY Complete engine and clutch change advice.
    By swa65 in forum Polo - Derby - Lupo - Fox
    Last Post: 11-11-2014, 09:05 PM
  4. Audi A3 Timeing belt change advice
    By Stuey1 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-10-2010, 04:36 PM
  5. audi a3 engine change
    By a3_mad in forum Audi A3 - Archive Topics
    Last Post: 11-04-2008, 08:52 AM
