Thread: Heater blower motor and wiper jets just stopped working HELP somebody Please
Results 1 to 10 of 11
  1. Heater blower motor and wiper jets just stopped working HELP somebody Please
    Oct 2018
    Bridlington
    Hi there im new here not sure if im posting in the right place if not my apologies. I have a 2005 vw touran and i have the same problem i have checked the motor it works fine and i have checked all fuses. my water jets arnt working either. Please can anybody shed a little light on what to try next?
  2. Re: Heater blower motor and wiper jets just stopped working HELP somebody Please
    1840 Post(s)
    Which HVAC system, standard heating, air con or digital?
  3. Re: Heater blower motor and wiper jets just stopped working HELP somebody Please
    May 2007
    17 Post(s)
    Quote Originally Posted by Rossh View Post
    I would check that there is 12V being supplied to the washer pump & blower fuses on the dashboard fusebox....
  4. Re: Heater blower motor and wiper jets just stopped working HELP somebody Please
    Oct 2018
    Bridlington
    Its standard heating with the knobs
  5. Re: Heater blower motor and wiper jets just stopped working HELP somebody Please
    Oct 2018
    Bridlington
    How do i test that please?
  6. Re: Heater blower motor and wiper jets just stopped working HELP somebody Please
    May 2007
    17 Post(s)
    Just switch the ignition on and probe the little test points on top of the fuses with a voltmeter or test light. Make sure you have 12V being supplied to the blower and washer fuses.
  7. Re: Heater blower motor and wiper jets just stopped working HELP somebody Please
    Oct 2018
    Bridlington
    Quote Originally Posted by Flash2 View Post
    Ok thank you. I will update when its done.
  8. Re: Heater blower motor and wiper jets just stopped working HELP somebody Please
    Oct 2018
    Bridlington
    Right i've checked and im only getting 2.4v to both the blower and the washers. What does that mean i have to do now please?
  9. Re: Heater blower motor and wiper jets just stopped working HELP somebody Please
    May 2007
    17 Post(s)
    It sounds like there isn't any power being supplied to the fuses, so those circuits can't function.
    The power for those fuse comes from a relay mounted on the power supply control module, located behind the dash on the driver's side....see the attachment.
    What I would do next is remove the relay and probe the 4 terminals of the relay socket on the module with your voltmeter (with the ignition on).
    I wouldn't jab your meter probe directly into the terminal slots though. Insert a straightened out paper clip, a sewing needle or something similar into the slots so you don't damage the terminals, then touch your meter probe to that to take a reading. You should find that two of the relay terminals (one large one and one small) have 12V and two have 0V.
    If that checks out OK, leave the ignition on and reinsert the relay. Listen for it clicking as you push it in. If the voltages were OK and the relay clicked when reinserted that suggests the relay itself is faulty.
  10. Re: Heater blower motor and wiper jets just stopped working HELP somebody Please
    Oct 2018
    Bridlington
    Thank you sooooo much for the advice. It was a faulty relay i replaced and hey presto it worked. Thank you so much again and just for future referance it was relay 460 above the interior fuse box. Thanks
  1. Golf mk5 heater blower stopped working melted wires
    By Mickyroo in forum Golf MK5 - 2004 - 2009
    Last Post: 22-11-2015, 02:08 PM
  2. Question Washer motor and heater blower fan stopped working VCDS scan included
    By adamkm in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-09-2014, 01:17 PM
  3. Heater/Blower stopped working
    By scottjay86 in forum Golf MK3 - 1993 - 1999
    Last Post: 26-02-2010, 12:10 AM
  4. Please Help Heater Blower stopped working?
    By JAZZK in forum Golf MK3 - 1993 - 1999
    Last Post: 21-03-2009, 02:17 PM
  5. Please Help Heater/Blower Motor Intermitant now stopped?
    By waynex1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-07-2008, 09:30 AM
