Thread: Allroad spacer question,needed for ET28 offset?
  1. Allroad spacer question,needed for ET28 offset?
    Oct 2018
    Bury St Edmunds England
    Hi guys,
    First post, diving straight in. Looking to buy a second set of winter wheels for the bus. Originally from an A5, all correct size wise, centre bore etc and are 7.5J but with a tiny difference in offset. Will I get away with the standard bolts with a 3mm difference? Tyre size staying the same at 225 55 17.
    cheers
    Mat
    2005 Allroad 2.5TDI auto in full silver
    2017 Leon ST Xcellence Technology 184 manual Boheme Purple mapped,brisk
  2. Re: Allroad spacer question,needed for ET28 offset?
    Dec 2010
    CD UK
    6 Post(s)
    Welcome Mat.
    Although the A5 wheels are 3 mm further in, that's just the centre line and not the internal mounting face of the wheel. If they're the same width then the overall shift is 3mm inwards. Your existing bolts are fine and are the same as for the A5.
    Out of curiosity, what size wheels do you have for your Leon? I know they're a different offset (50ish) as I just fitted some 18s to a Performance Packed Cupra 300 and had to be very choosy because of the calipers on the larger 370mm brakes. Not all 18s fit. If you're after some 17s I can give you a great link. Don't know if you can message through this or the "Cupra" forum if your post count prevents here.
    MY2014 A6 allroad 245PS, my 8th Audi in 20 years - all quattros. 15th VAG car (incl 2 used ones).
  1. A6 Allroad wheel offset/Back space
    By Bahamacharger in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-12-2016, 05:50 PM
  2. What is correct offset ET for Allroad
    By mhobson in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-10-2011, 02:42 PM
  3. allroad offset question
    By ben0069 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-05-2011, 10:19 PM
  4. spacer question golf vr6 help needed!!
    By probert993 in forum Golf MK3 - 1993 - 1999
    Last Post: 10-11-2009, 06:51 PM
  5. Spacer Question
    By redducati in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-02-2009, 10:05 PM
