Thread: 62 Plate Alhambra SE LUX Edition Error codes
  1. 62 Plate Alhambra SE LUX Edition Error codes
    Oct 2018
    London
    Hi Everyone,
    I've just bought an Alhambra SE LUX 2.0 TDI 62 Plate.
    I've had a few VW Golf's and any faults that appear I resolve myself with the help of VCDS; However I'm a little confused with the error codes the Alhambra has got so I was hoping people on here may help.
    Here's the three error codes thrown up:
    Address 09: Cent. Elect. (J519) Labels: Redir Fail!
    Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
    Component: BCM PQ35 M 021 0068
    Revision: BC021001
    Coding: 40590A3B8925F1C0508800C87400816443519288636D2D6264 80C72000C1
    Shop #: WSC 00020 790 00000
    VCID: 3E74E5BAA9ECF5BAE7-806A
    Subsystem 1 - Part No SW: 7N2 955 119 A HW: 7N2 955 119
    Component: WWS 120522 31 0032
    Serial number: 120612041639
    Coding: 004DBD
    Subsystem 2 - Part No SW: 7N0 955 559 HW: 7N0 955 559
    Component: RLFS 021 0024
    Serial number: Y12M06D20h14m15s39S4
    Coding: 0280DD
    Subsystem 3 - Part No: 7N0 951 171 A
    Component: DWA-Sensor 00 002 0206
    Coding: 000000
    Subsystem 4 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Coding: 000000
    1 Fault Found
    00924 - Relay for Headlamp Cleaning System (J39)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 31
    Mileage: 325970 km
    Time Indication: 0
    Date: 2006.14.15
    Time: 08:42:43
    Freeze Frame:
    Term 15 On
    Voltage: 14.50 V
    ON
    ON
    ON
    OFF
    OFF
    Address 18: Aux. Heat Labels: 1K0-815-071.clb
    Part No: 7N0 963 271 E
    Component: Zuheizer 051 2940
    Revision: 00051000 Serial number: 09024297000000
    Coding: 0000041
    VCID: 3664FD9A41DC3DFA3F-8062
    1 Fault Found
    01415 - Recirculating Pump (V55)
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 31
    Mileage: 325970 km
    Time Indication: 0
    Date: 2006.14.15
    Time: 08:42:60
    Freeze Frame:
    OFF
    Temperature: 43.0°C
    Temperature: 45.0°C
    Voltage: 14.53 V
    Address 72: Door, Rear Right (J389) Labels:. 7N0-959-794.clb
    Part No SW: 7N0 959 794 H HW: 7N0 959 794 H
    Component: TSG HR H01 0553
    Revision: Serial number: 0000128405793
    Coding: 01006C200001411001
    VCID: 48988362FB28BB0A5D-801C
    1 Fault Found
    02115 - Locking Unit for Central Locking
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 73
    Mileage: 325985 km
    Time Indication: 0
    Date: 2006.14.16
    Time: 08:32:27
    Address BE: Slid. Door Rear Left
    Cannot be reached
    Address BF: Slid. Door Rear Right (J731) Labels: None
    Part No SW: 7N0 959 244 A HW: 7N0 959 244 A
    Component: Schiebetuer_r 005 2314
    Serial number: 12224821
    ASAM Dataset: EV_AST A03704
    ROD: EV_AST.rod
    VCID: 377AF09E8ED6C4F224-8062
    1 Fault Found
    49153 - Supply voltage
    U1011 00 [008] - Voltage too Low
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 67
    Mileage: 325934 km
    Date: 2070.14.08
    Time: 18:01:35
    Voltage terminal 30: 7.9 V
    Sliding_Door_Motor_Current: 0.0 A
    Sliding_Door_Clutch_Current: 0 A
    Sliding_Door_Locking_Pawl_Motor_Current: 0 A
    Front button for automatic sliding door: not activated
    Rear button for automatic sliding door: not activated
    Installed on left side: No
    Installed on right side: Yes
    Pinch protection sensor: not activated
    Latch_Ajar: operated
    Latch_Pawl: operated
    Sliding door indicator lamp: not active
    Sliding door indicator lamp 2: not active
    Activation: motor for automatic sliding door: not active
    Automatic sliding door coupling motor activation: not active
    Motor activation for enabling ratchet release: not active
    Sliding_Door_Feedback_Motor_Opening: not active
    Sliding_Door_Feedback_Motor_Closing: not active
    Sliding_Door_Feedback_Locking_Pawl_Motor_Opening: not active
    Sliding_Door_Feedback_Locking_Pawl_Motor_Reversing : not active
    Sliding_Door_Feedback_Clutch_In: not active
    Sliding_Door_Feedback_Clutch_Out: not active
    Sliding_Door_Feedback_Indicator_Light_Front: not active
    Sliding_Door_Feedback_Indicator_Light_Rear: not active
    AD-Value clamping_Protection_Seal: 100
    Position of automatic sliding door: 0
    Status_Sliding_Door: latch secondary position
    Play protection: motor for automatic sliding door: not active
    Play protection: motor for enabling ratchet release: not active
    Play protection: automatic sliding door coupling motor: not active
    Status_Locking_Pawl_Motor: closed
    Status_Clutch_Motor: Open
    Can anyone help with resolving the above error codes? Where can I locate and replace/rectify the affected control unit? P.S. I have just installed a brand new Bosch AGM Battery
    Thanks in Advance!!!!
  2. Re: 62 Plate Alhambra SE LUX Edition Error codes
    1841 Post(s)
    Make sure it is fully charged on the new battery, clear the codes, drive, read again see what happens. The headlight wash relay, does it have headlight wash?
  3. Re: 62 Plate Alhambra SE LUX Edition Error codes
    Oct 2018
    London
    Hey,
    I cleared all the codes and they come back immediately after!?
    *Edit* Yes the car has headlight washer system
  4. Re: 62 Plate Alhambra SE LUX Edition Error codes
    1841 Post(s)
    Please message me the UK REG or VIN and I can dig deeper on Monday at work.
  5. Thumbs up Re: 62 Plate Alhambra SE LUX Edition Error codes
    Oct 2018
    London
    PM'd - Thanks!
  6. Re: 62 Plate Alhambra SE LUX Edition Error codes
    1841 Post(s)
    According to their date stamps those codes are old, some from 2013, don’t trust the VCDS auto clear, it does not always work, do each one individually.
  1. Alhambra 54 Plate Aircon Fault
    By Grant620 in forum Alhambra
    Last Post: 23-06-2017, 04:44 PM
  2. Error codes help
    By magic123 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 10-09-2013, 09:15 AM
  3. Help with my Error Codes please - What do they mean?
    By Dan Glibitz in forum VCDS - Help Requests
    Last Post: 06-06-2010, 11:43 AM
  4. Question Alhambra Fault Codes
    By andy721 in forum Alhambra
    Last Post: 12-02-2010, 06:53 PM
  5. two error codes
    By aboola40m in forum VCDS - General Questions
    Last Post: 28-06-2008, 05:15 PM
